Old 11-29-2009, 10:27 AM   #1
sonseeker
sonseeker's Avatar
Question PLEASE HELP-Bracket that holds carrier bearing on drive shaft
Doing some work on the 72 and went to reinstall the carrier bearing brcket and 3/8" bolts won't tighten up!! Can't get at them to tap for 7/16" so what tto do now? The bed is off the truck! Help!!!
sonseeker is offline   Reply With Quote
Old 11-29-2009, 11:11 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: PLEASE HELP-Bracket that holds carrier bearing on drive shaft
Is this the plate that mounts to the frame and then the carrier baearing mounts to it? If so mine have bolts with nuts?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-29-2009, 12:38 PM   #3
sonseeker
sonseeker's Avatar
It is under the back half of the cab. The plate on top has clearance holes for 3/8" and the bracket around the shaft is tapeed for 3/8" nc! The bolts will not tigten up nor is there enough room to drill and tap for 7/16!
Do i have to remove the entire drive shaft or?
Old 11-29-2009, 06:03 PM   #4
edco joe
Wink Re: PLEASE HELP-Bracket that holds carrier bearing on drive shaft
soonseeker.....i have complete bracket assembly its free ...let me know if ya still need:
edco joe is offline   Reply With Quote
Old 11-29-2009, 09:32 PM   #5
sonseeker
sonseeker's Avatar
edco joe thanks for the offer i will let you know. What i have found out this is a new unit (by previous pwner) and could it possibly be METRIC bolts and that why 3/8 nc will not tighten up? Going to stop into local bolt supplier in the a.m. ,what size is just a little bigger than 3/8? pitch?
