Old 11-30-2009, 05:46 AM   #1
karl
karl's Avatar
9 inch swap
How hard would it be to swap in a 9in rearend for my 75 half 2 wheel drive? I would like to be able to swap gears fairly easy. thanks.
karl is offline   Reply With Quote
Old 11-30-2009, 11:48 PM   #2
f.monroe
f.monroe's Avatar
Re: 9 inch swap
Pretty easy if you get the right rear axle . Search the internet and you will find that some Ford big cars came with a 5 on 5 inch bolt pattern and are almost the exact same width as our trucks . They can even be had with factory rear disc brakes and the 5 on 5 bolt pattern .You would only need to trim the existing mounts and weld on a pair of universal mounts that can be bought at retailers like Summit . I see them on the internet at times and the rears that will work in our trucks are not that expensive . Most have serious highway gear since they were used in the big luxury cars but that is easily cured .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 12-01-2009, 03:33 AM   #3
karl
karl's Avatar
Re: 9 inch swap
I know the ford 9in is common unlike some of the 12 bolts. I like the idea of being able to swap the pumpkin so easy. I just had my 12 bolt posi rebuilt and set up for my chevelle and now im stuck with the gear i chose. With the truck i want the option to tow or cruise. Probably use bags all around and i have a 454 to swap in place of the 350. Also ford has a wide selection of gears for the 9in.
Old 12-01-2009, 04:51 AM   #4
2tons of fun
Re: 9 inch swap
so, it will still take you 2+hrs to swap, and 3-4qrt of oil, because who is cheap/dumb enough to reuse oil.
you will be ahead if you just bought an entire second axle and setup matching disc brakes.
just take the calipers off, then dshaft, shocks, ubolts. clean and no waste. no need to bleed the brakes, reseal or refill.
2tons of fun is offline   Reply With Quote
Old 12-01-2009, 08:24 AM   #5
csa daddy
csa daddy's Avatar
Re: 9 inch swap
i had a ford 9 inch an broke both axles in it pulling of from stop lights . an no i was not spinning or anything just eased out on the clutch an bam .they kept snapping at the wheel bearing where it bolts to the axle tubes . by the way all the truck had in it for motor was a 300 6. so be carefull what axles you get the more splines thhe better
csa daddy is offline   Reply With Quote
Old 12-05-2009, 03:14 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 9 inch swap
79 f-150 housings are about a inch wider. Come with big 3 1/4 axle tube and the heavy duty center sections. And the drive shaft needs to be a bit longer also. And you to fab the brake lines fords brake lines come down the left side of the frame.
KQQL IT is online now   Reply With Quote
Old 12-05-2009, 08:17 PM   #7
78-5.3
78-5.3's Avatar
Re: 9 inch swap
are these 5 on 5 though???
78-5.3 is offline   Reply With Quote
Old 12-05-2009, 08:45 PM   #8
nlped
nlped's Avatar
Re: 9 inch swap
No, the bolt pattern is wrong, but all you would have to do to remedy this is to pull the axles (which you would have to do anyway to install the gear choice that you want) and have them and the drums drilled to the appropriate 5x5 bolt pattern. They would just drill the appropriate pattern between the existing pattern. And yes, this would be plenty strong...and I have never heard of a 300 straight six breaking a 9" axle...EVER.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-05-2009, 09:45 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 9 inch swap
I bought moser axles. Ordered them 5x5 and took a die grinder to the drum's, they register on the axle flange...
Old 12-06-2009, 11:07 AM   #10
68 TT
Still plays with trucks
68 TT's Avatar
Re: 9 inch swap
I swapped pumpkins in my old drag car all the time. Once you know what you are doing it will take all of 20 minutes to swap out a pumpkin in a 9".
I even had storage boxes that fit in a cabinet on the trailer that held the spare pumpkins and kept them clean & undamaged.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 12-06-2009, 11:13 AM   #11
68 TT
68 TT's Avatar
Re: 9 inch swap
There are 28-spline axle 9" rear ends that are not very strong. The ones you want are 31-spline.
The easy way to tell is the 28-spline rear ends have smaller bolts holding the axle retainer plates in place. If it has 9/16" heads on the retainer plate bolts it is a 28-spline rear.
You probably had the 28-spline 9" with a 6-cyl.
Old 12-06-2009, 11:15 AM   #12
68 TT
68 TT's Avatar
Re: 9 inch swap
Frank
Any idea what year and application the big cars had the 9" with the 5 on 5 bolt pattern?
