![]() Join Date: Feb 2008
Gauges dropping out?
The other day my wife told methere gauges in our 05' Silverado kept dropping out then going back to normal. Sure enough when i drove it the gauges did it a few times too me as well. The Fuel,temp and oil pressure gauge needles would drop to nothing then go back to normal a few seconds later. Then the fuel gauge itself would do it. Any one have a idea of what it could be. It's an 05' silverado just shy of 40,000 km's.
![]() Join Date: Nov 2008
Re: Gauges dropping out?
Not sure if it is applicable to your 05 but, there was a campaign to replace the instrument cluster on the 04s. May be worthwhile to check at the dealer to see if yours has an open campaign.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
Would it apply to the '03 too? Is a "campaign" the same as a recall?
My odometer stopped displaying today and my speedo occasionally shows my speed being higher than it actual is (It will show a constant ~10mph high until I turn the truck off and back on).
Mike Lackey '68 C10 '49 6400 |
Gm actually did a recall on the gauge clusters. I don't know what all years were covered, but my 03 Sierra was included. However I had 75,000 miles on the truck at the time, and the recall only covered up to 70,000.
![]() Call your local dealer and they will help you out with it. New cluster costs about $300 IIRC ![]() |
Bugger. It covers what the gauges are doing, but I've got 105k miles. The Odometer may be an entirely unrelated issue.
