Old 10-15-2009, 07:34 PM   #1
cwilkie
Chance
cwilkie's Avatar
Remote Power Door Locks
I installed a set of one peice windows from One Piece Products. I want to purchase and install a set of remote power door locks from LMC. Does anyone know if this will work since I don't have stock windows in my truck anymore? Thanks.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 10-18-2009, 12:59 PM   #2
cwilkie
Chance
cwilkie's Avatar
Re: Remote Power Door Locks
Any advice guys?
BB 396 w/TH400
BB 496 w/TH400
Old 10-18-2009, 02:27 PM   #3
mbgmike
I have heard that these windows do not go straight up and dowm. Is that true? I have never installed them. I have heard they are not simple to install.If they do go up like the old ones you should have no problem. If not then maybe there is a problem. Your actuator will be bolted at the back of your door just under the door lock rod. You will have to see how far they go towards the back. You have to bend the new rod to work and they are semi adjustable.
I personally would buy a better set than the ones LMC sells. Their instructions are poor and printed in china w/o much detail.Their are better sets available. They are a pain to get right like if you want the horn to beep and exterior lights and or inside lights to come on and such
mbgmike is offline   Reply With Quote
Old 10-18-2009, 02:41 PM   #4
subtle71
Granddad's Ol' Truck
subtle71's Avatar
I am not using the One Piece or LMC parts, but I do have the Brothers one-piece windows kit and power door locks tied in to my security system. The Brothers kit does go up and down withour any clearance issues. The door lock actuator fits to the rear of the inner door (directly below the door lock plunger). It mounts in the area between the door panel and the window track. I hope this helps.
1971 Chevrolet Custom 10 short step-side
2005 GMC Sierra SLT 2500HD crew cab 2wd
[I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side
subtle71 is offline   Reply With Quote
Old 10-18-2009, 02:48 PM   #5
mbgmike
Yes if they are the Brothers windows they will work fine. I just heard that the One Piece go down and then rotate. All the kits for the actuators mount in the same location. The problem is with the window rotating.
If they go stright up and down there should be no problem at all. When viewing there install instructions it looks like the brackets would be fine to clear the actuators but its hard to tell from there instructions. We do windows all the time but never ones from "One Piece". I don't see how it could not be worked out however, we put all kinds of stuff in vehicles that are made to fit something else just might have to adapt it to work. I don't see a real big problem.
Old 10-18-2009, 08:32 PM   #6
vegaschevy
Ill be doing this as well, doesnt OPP make a power window kit for the kit?
vegaschevy is offline   Reply With Quote
Old 10-18-2009, 09:16 PM   #7
chevyboy55
chevyboy55's Avatar
I went with A1 Electric. I a keyless entry,alarm & starter kill. I did not have any problems but I used Brothers one piece windows.
http://www.a1electric.com/alarm.htm
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 12-10-2009, 11:48 PM   #8
cwilkie
Chance
cwilkie's Avatar
Has anyone ever tried this kit?
http://www.a1electric.com/Merchant2/...Code=W01F-712T
Does anyone have the link to Brothers' kit?
BB 396 w/TH400
BB 496 w/TH400
