Old 12-15-2009, 11:27 PM   #1
jlaird
jlaird's Avatar
SECTIONED CROSSMEMBER complete package
I am selling my sectioned crossmember with everything to complete the swap. It is sectioned 1 3/8". I included a picture to show you that the bottom of the crossmember sits 1 5/8 off the ground. This is with a 29.5" tall tire and belltech 3" drop spindles and ART arms. You can go lower if you have a modified stock lower control arm with a cup welded in for the airbag. I had this setup laying frame but got ART arms which actually raised it to where it sits as you see it in the pictures. There are NO clearance issues. Everything is freshly painted or powder coated. (Dont mind the dust in the pictures!) Below is a list of what is included. Total cost is a lot more than my asking price...you do the math. All parts are brand new with 0 miles except the pitman arm and the idler arm. Those did not need replacing. Ok, here goes:
1. Crossmember itself. I will include all Grade 8 hardware for everything
2. New control arm U-bolts and nuts
3. Tubular motor mounts with rubber engine mounts.
4. Upper bag plates
5. 4 MOOG tie rod ends
6. Tie rod
7. CPP connecting sleeves
8. Idler arm and pitman arm
9 mount that connects idler arm to frame
10.Monroe Shocks
11. Shock studs
12. Upper Shock mounts
I'm asking $500 for everything.
jlaird is offline   Reply With Quote
