Old 12-29-2009, 02:49 PM   #1
hotrod_991
hotrod_991's Avatar
lowest drop w/o notch
ok I have a 77 chevy lb I am wanting to bring down alittle. not slam or anthing like that. What would be the easiest and lowest drop kit that i can bold on with out notching? looking for 2 or 3 in front and 4 or 5 in back. Thanks in advance for the help.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 12-29-2009, 03:06 PM   #2
SCOTI
SCOTI's Avatar
Re: lowest drop w/o notch
A 2/4 drop would work w/o notching the rails for sure. You could possibly do a 4/6 if you didn't load the truck down often. Bolt-in c-sections are pretty easy to install if there's concern (Western Chassis, Bell Tech).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-29-2009, 03:57 PM   #3
hotrod_991
hotrod_991's Avatar
Thank you for the fast responce. I am not planing on loading it down with anything sept maybe from time to time but deff not a work truck. Do you think with a 4/6 i would be able to move my GSXR750 around with out damaging anything? The reason i dont want to notch is that i have no means of cutting the frame and i dont want the real lowered look. More after the agressive streetrod stance. Thanks
Old 12-29-2009, 04:06 PM   #4
SCOTI
SCOTI's Avatar
All it takes to cut the frame is a drill (for the corners) & an angle grinder w/a cut-off wheel. You can ususally get an angle grinder cheap on Craigslist or rent one @ a local rent-all place.
The 4/6 drop would be close & likely rub w/a 5-700# load @ speed on dips/bumps in the road surface.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-30-2009, 09:59 AM   #5
hotrod_991
hotrod_991's Avatar
how much of the structurel integrity do you lose with the notch? Is it bolt or weld cause i cant weld at all and wouldnt want to learn on my frame.
Old 12-30-2009, 10:09 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
You don't loose any structural integrity. In fact it might actually be stronger at that point due to the bracing built in to a C-notch.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-30-2009, 11:08 AM   #7
SCOTI
SCOTI's Avatar
A good idea are the two bolt-in style notches I listed. I've used both Western Chassis & Bell Tech so I know they're solid, well built parts. I like the type of bolt-in notch that @ least partially wraps around the top/bottom of the frame @ some point. The Western Chassis would be my top choice.
Use the provided GRADE-8 hardware to install the notch that so you know it will be structurally sound. If desired, you can 'practice' your welding skills on the outer edges (if you have the equipment & after getting the basics down on multiple pieces of scrap first).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-30-2009, 12:29 PM   #8
smbrouss70
smbrouss70's Avatar
I've made nice clean cuts on a frame with a jigsaw before. Just make sure you have plenty of metal blades. It's not the fastest way, but it is easily controlled.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-30-2009, 01:19 PM   #9
hotrod_991
hotrod_991's Avatar
now is the c notch from western 6 inch drop with 4 inch drop leaf springs or just the notch kit? its just and axle flip isnt it. did that on my 86 in highschool but we cut perchs off top and welded them on the bottom and removed the thick leaf
Old 12-30-2009, 01:47 PM   #10
hotrod_991
hotrod_991's Avatar
jsut got off the phone with western. decided to go with the complete 3/5 kit with the bolt in notch. Very reasonable price as well. Manuel was awesome guy to talk with. Thanks for all the help guys I really apreciate it. My build sheet is growin by the day.
Old 12-30-2009, 02:15 PM   #11
SCOTI
SCOTI's Avatar
Pretty straight forward install but don't hesitate to seek help if you run into anything. The WC c-notches are round so a sawzall or jigsaw will get you a nice clean cut. I use the notch to make a cardboard template so the material I cut out is nice & consistent from side to side (professional looking).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-31-2009, 08:01 PM   #12
andrewmp6
Yeah a small notch like hes talking about will keep the frame strong and you can still use it as a truck.
Old 01-01-2010, 06:31 AM   #13
hotrod_991
hotrod_991's Avatar
yea im going to tackle that soon as i get home. and i like the idea of still being able to haul my bike around at times.
Old 01-01-2010, 01:03 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Just make sure when you make your cuts you do not create and sharp corners. This will create a potential stress point that "could" eventually crack.
Articles-
"Refining Sierra"
Old 01-01-2010, 05:00 PM   #15
hotrod_991
hotrod_991's Avatar
Thanks for the tip that would not have been good if I would have done that
Old 01-01-2010, 05:44 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
This my pile with out a notch in it. It rarely bottoms the axle into the frame the rear is flipped with a big 10 7 leaf pack This is with 3 leaf light duty leaf pack and still no notch
Old 01-02-2010, 10:49 AM   #17
hotrod_991
hotrod_991's Avatar
that looks nice I am really stoked to get my drop kit on. What are you using for the front? prings or spindles? btw love those rims i was looking at a set a few days ago tryn to decide between the stock rallies and aftermarket
Old 01-02-2010, 07:19 PM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
I cut two coils off the stock springs. Thats probably not the correct way but...
