Old 09-18-2010, 11:56 PM   #1
kgmunro
axle shaft question
Are there any stock junkyard axle shafts that will bolt into my 66 suburban rear diff? I want to go from 6 bolt to 5 bolt.
kgmunro is offline   Reply With Quote
Old 09-19-2010, 12:40 AM   #2
Captainfab
60-66 Nut
Re: axle shaft question
I believe I answered this question in your other thread asking basically the same question
Old 09-19-2010, 06:09 AM   #3
kgmunro
Thumbs up Re: axle shaft question
Actually...no. What I want to know is if any axles will fit the existing diff to make it a 5 bolt pattern. I got a private message telling me what will work, so its ok captain...thanks .
Old 09-19-2010, 08:52 AM   #4
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
IF the pm said that '71-'72 axles fit, it is misleading. they will work but they won't be right, the bearing surface will move inboard on the newer axles and the newer brake drums will hide the mismatch of the narrower '66 brake shoes. It's been done, there was a thread in the past about this.
If it's some other "secret", there are probably hundreds of us who would truly appreciate being enlightened-please share the info
Larry
fleetsidelarry is offline   Reply With Quote
Old 09-19-2010, 08:59 AM   #5
kgmunro
ya you are right about the 71-72 axles thing... I guess the easiest and least expensive for me is to take the rear diff from my 85 and mount it in.. But has anyone done this on a suburban body and been able to use the stock 8 inch gm truck rally wheels? The fact that the diff is 1.5 inch wider has me nervous...is there lots of room back there for the extra width and wider rim??
Old 09-19-2010, 08:59 AM   #6
fleetsidelarry
Senior Car Nut
double posted-don't know what happened
Larry
Old 09-19-2010, 03:20 PM   #7
raycow
If overall width is a concern, have a machine shop redrill your 65 shafts to the 5 lug pattern. This should cost less than buying the aftermarket 5 lug shafts.
Ray
raycow is offline   Reply With Quote
Old 09-19-2010, 03:23 PM   #8
kgmunro
Well that was my original idea but they won't do that here because they say it will take the integrity away from the axle hub area
Old 09-19-2010, 05:13 PM   #9
fleetsidelarry
Senior Car Nut
you should be OK with standard backspacing (which I think is 3.25"). Do you have a current 6-lug rim you can measure for width and backspacing? and can you measure your current clearance to the fender lip? it shouldn't matter that it is a suburban, it should be the same as a fleetside. remember, we're only wider by 3/4" each side
sorry about the earlier double post, I must have pushed a wrong button
Larry
Old 09-20-2010, 03:39 AM   #10
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Give Moser a call
http://www.moserengineering.com/moser/shop-services/
I've never done this myself, but have heard great things about them with this service.
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 09-20-2010, 06:13 AM   #11
kgmunro
I have my 85 chevy coming home soon so i will be able to measure the width of the diff with rims installed, this should help to figure this out. Thanks for the knowledge guys. This is one cool website!
