Old 12-31-2009, 07:03 PM   #1
ryhan87
Distributer Question
I have a 72 GMC with a 250 CI Inline 6 and i want to put a HEI Distributer but Im not getting much help from any of the parts stores. Could someone tell me what year they switched to HEI or give me a part number or something for the correct distributer.
ryhan87 is offline   Reply With Quote
Old 12-31-2009, 07:06 PM   #2
OhOneWS6
OhOneWS6's Avatar
Re: Distributer Question
Looks like you can use one from a 77 Nova or a 75 Camaro according to post #25
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
OhOneWS6 is offline   Reply With Quote
Old 12-31-2009, 07:20 PM   #3
Mike C
Mike C's Avatar
HEI showed up in '75 across the line with GM. You should be able to use any inline 6 HEI through the last year of the inliner. '85? Not sure what last year was.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-31-2009, 07:35 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
a tip on this.If you plan on adding AC to the 250 then you need to get the dist with the divorced coil.The AC will not fit with the coil in cap dist.At least that is what I have been told.
BTW I have bought 2 Hei for 250 and payed $25.00 for each.Local JY.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-31-2009, 07:48 PM   #5
Wrenchbender Ret
Like Mike says it came out in 75. The 75-77 was the divorced choke type. It is best to get one from a salvage & clean & repair it yourself. If you go to a parts store each unit is separate. The dist., coil, cap & wires. You will have well over $100 in it.
Wrenchbender Ret is offline   Reply With Quote
Old 01-01-2010, 02:10 PM   #6
camaney
or just go to ebay i just buy for $50 brand new
camaney is offline   Reply With Quote
