Please help me ID my frame
I am having some problems IDing my frame.
I have a 67 short bed step side Disks up front and leafs in the back and it has all the stock rivets on the hangers and 5 lug all the way around. I was told by a few people that the frame was a 73-87. so i bought a c-notch kit for a 73-87 and the notch is straight, and my frame is curved. So could some one ID my frame please? Thanks In Advance!!! Pics Rear ![]() Front Driver ![]() Front Pass ![]() Center ![]() I have pics of the upper front if you guys need them. Thanks again Last edited by Wilson_; 12-02-2008 at 06:08 PM. |
Re: Please help me ID my frame
I had a 67 GMC that had factory leafsprings.
As for the 5 lug bolt pattern, my first guess is that it may have been swapped from a 71-72.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
Thanks,
I am starting to think that its a 67 frame with a newer front end. Damn once again i bought the wrong stuff ![]() |
A guy with a truck
Definitely a 67-72 frame. Leaves were optional. Pics of the front top side and steering box mounting would help determine if it's a '67.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
67-72 frame with stepped lower controll arms and spring clamps.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Thanks for the replys guys!!
Here is the pic you guys asked for. ![]() So when i buy front end parts, like springs, balljoints ect. what year do i look for? Thanks again |
#7 | |
![]() im guessing the springs were heated and it was too low, because the clamps are reversed and are spacing out the spring so it lifts the truck. I have been fixing crap like this for a while on this thing Last edited by Wilson_; 12-03-2008 at 04:09 AM. |
PROJECT 7DEUCE
Im not 100% sure but it looks like you should be able to order 72 front end stuff for it.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 12-03-2008 at 08:27 AM. |
Thanks for the info guys!!
#12 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Your front suspension is definitely pre 73 stuff as it uses steel screw in control arm bushings. In 73 they went to pressed in rubber bushings.
so a update...
I figured everything out last year and forgot to update. 67 gmc frame 73-87 front upper arms, spindals and brakes 67-72 modified lowers thanks for the help
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
