door skins.
i thought id show some pictures for people wanting to know how to do the bottoms of the doors.. i skinned the inside and outside today.. first step is to cut the outside where you want it then take a grinder and grind the edges then it comes right off... the on the inside there are a few braces you cut the spot welds there.. and then cut the spot welds on the sides and then the inside comes off.. im sorry i dont have great steps but then the next thing is i test fitted it all and basically put the puzzle back together im going to leave an overlap on the inside to give me a bit to weld on.. heres some pics.. enjoy.. got about 6 hours total on it.. ive never skinned a door and so far its a piece of cake..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Re: door skins.
Nice work. I just did mine
Re: door skins.
its not as bad as people think they are.. agree?? the guy helping me said if i can do this i can skin an entire door its that simple
![]() Join Date: Nov 2004
Re: door skins.
Good job, I have to do this as well someday.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: door skins.
its not bad at all.. about 100 bucks maybe for the skins maybe cheaper.. and maybe 5 hours of your time this was my first time so i was getting taught how to do it...
Re: door skins.
thanks for your time and showing us how you did this. It is on my list of things to do as well and seeing how you did it make it just a bit more doable for me I hope.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
Re: door skins.
Did you do any type of coating on the inside of the door when you were done? If so what and how? I need to do the same thing. Thanks for the info.
Dale |
Re: door skins.
Looks great!
Did the detail lines all line up for you? Did you have to do any massaging to get the lines all lined up on the inside, like some of the older threads showed? Also, how did the gauge of the patches compare to the original door?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 01-16-2010 at 09:49 AM. |
Re: door skins.
its the same gauge.. i got them from keystone automotive.. and i just used undercoating on the backsides. and the lines matched up fairly well on the inside i made a slit and then massaged it and welded it back up but it was a very simple task.. for an 18 year old that never done it before i say i did an alright job.. my boss says if u can skin the bottom of a door u can skin a whole door because he says this is harder
Re: door skins.
and the good news is im not cutting the speaker holes out im going to leave it stock looking and make boxes to go under seat for my 6x9 speakers and an 8" sub
Grand PooBaa Member
Re: door skins.
I have a full doodskin to replace. Do I grind the folds all around the door, or is there a way to pry them up?
Re: door skins.
if not reusing the panels just take a flap disc and grind the edge down. Takes hardly any time. too much work to pry up. We do that on old and new cars
Re: door skins.
It's not that bad v-dog grind outside edge with grinder keep it flat you will see start to separate go all the way around like this and pull off outer door skin and on the inside there will be a small strip left take a pair off plyers and work it off
Grand PooBaa Member
Re: door skins.
Am I grinding the edge by the window felt? Also the side where the door opening meets the cab, do I grind at an angle or just grind the edge down?
#15 | |
Re: door skins.
No. You just grind the bottom and up both front and back. Just grind it flat 90 degrees to edge. You will see it comes off rather easy after the three sides are gone. Like said i use a flap disk cause it does not make as many sparks but a solid disc works great of even a HD sander with real course grit will work. You will see when it is ground thru, you will have three layers of metal. Mike that used to work here could skin a door in 45 minutes when he was sober ![]() Last edited by mbgmike; 01-17-2010 at 09:05 PM. |
#16 |
Re: door skins.
VDOG HERE IS A LINK TO VIDEO THAT MIGHT HELP BE PATIENT IT'S A LITTLE SLOW BUT YOU WILL SEE IT WILL GIVE YOU A GOOD IDEA
#17 | |
Re: door skins.
see its easy |
#18 |
Re: door skins.
all i did was cut where i wanted to skin on the outside then grinded the sides down and the panel comes right off.. took less then five minutes
#19 |
Re: door skins.
if you replace the inner skin then there are a few spot welds you gotta take care of but that aint bad either
