![]() Join Date: Jun 2009
static drop
Is a static drop 4/6 as good as air suspension drop if I don't haul anything heavy in my 1972 chevy c10? Thanks.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: static drop
It's even good if you do haul stuff.
If you have really heavy loads you can use air bags in the place of the rear coil springs. Search around here in the suspension section. Alot of members running a 4/6 drop. Last edited by lolife99; 01-30-2010 at 10:31 PM. |
Tot Roddin'
Re: static drop
As lolife99 mentioned, you will be fine running a 4/6 even with the occassional load.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: static drop
what about towing?
1968 LWB C20 / AC / Wood Bed |
Tot Roddin'
Re: static drop
That might depend on how much weight you will be pulling. You could even replace the rear shocks with bags running shrader valves; fill them up more when you need to tow and then air them lower when you want to cruise.
Re: static drop
Thanks guys, I was thinking of getting the 4/6 drop kit from ECE. Can I use this without a c-notch?
Tot Roddin'
Re: static drop
Yes, a c-notch is not required. Refer to my build thread (Project: Blank Slate) for a step by step install.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-31-2010 at 01:17 PM. |
