Old 09-22-2009, 09:05 AM   #1
JCaldwell
454 Timing ?
Hey guys I just got my 454 fired up this weekend for my 72 K20 it is bored .40 over, a .510 lift comp cam aluminum intake and 770 holley and its running and 18 degrees retarded just fine and smooth when I turn the distributor to 0 when running it gets real choppy like it should but when I go to give it gas it falls on its face..anybody got any ideas? Thanks
72 K20 Project now!
70 GMC K20 (Farm truck) on 35's
71 Gmc K20 (Parts truck)
72 Blazer (Parts)
74 3/4 ton (Farm truck) on 35's
84 3/4 ton K5 (Mud toy) on 38.5's
86 3/4 ton (puller) on 36's
98 Cummins (Puller) on 305's
JCaldwell is offline   Reply With Quote
Old 09-22-2009, 10:26 AM   #2
71tahoe
71tahoe's Avatar
Re: 454 Timing ?
1. The balancer spun and the timing mark is off.
2. Are the vacuum lines plugged while setting timing?
3. Timing tab is misaligned.
71tahoe is offline   Reply With Quote
Old 09-22-2009, 04:43 PM   #3
JCaldwell
Re: 454 Timing ?
well the vacuum lines are plugged but dont know about the other
72 K20 Project now!
72 Blazer (Parts)
Old 09-22-2009, 05:12 PM   #4
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: 454 Timing ?
were you reusing the old balancer?
If you did, there is a good chance that as mentioned by 71Tahoe that the outer ring of the balancer is spun from where it should be.
ProStreet68SB is offline   Reply With Quote
Old 09-23-2009, 12:30 PM   #5
JCaldwell
Re: 454 Timing ?
Yea its the old balancer..could that actually happen? What do you think the timing she be at?
72 K20 Project now!
72 Blazer (Parts)
Old 09-23-2009, 07:51 PM   #6
JimKshortstep4x4
Re: 454 Timing ?
Usually big blocks will run better with a lot of timing. I would try 12 degrees btdc and bump it up if needed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-23-2009, 08:37 PM   #7
mixermike
mixermike's Avatar
Re: 454 Timing ?
i'm running 24 degrees btdc on my 396 bored 40 over with comp cam
mixermike is offline   Reply With Quote
Old 09-25-2009, 05:08 PM   #8
JCaldwell
Re: 454 Timing ?
Oh wow 24 degrees maybe Im rite then..I was figuring about 8 to 10
72 K20 Project now!
72 Blazer (Parts)
Old 09-25-2009, 06:24 PM   #9
LONGHAIR
Re: 454 Timing ?
Are you sure that you are not confusing advanced and retarded? It has happened more than once.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-30-2009, 04:45 PM   #10
JCaldwell
Re: 454 Timing ?
Retarded is BTDC right?
72 K20 Project now!
72 Blazer (Parts)
Old 09-30-2009, 05:08 PM   #11
john
member #16
john's Avatar
Re: 454 Timing ?
BTDC is advanced. (before top dead center)
john is offline   Reply With Quote
Old 09-30-2009, 05:29 PM   #12
Rreemo
Rreemo's Avatar
Re: 454 Timing ?
Another piece of advice on this....on an engine like that I wouldn't screw around with setting it at base. You need to be timing that thing at full advance. It's hard for me to say how much without knowning a little more details about the engine, most importantly compression ratio.....but assuming it's in the 9.5 - 10:1 range I'd suggest that you start around 32 degrees, and work your way up 2 increments at a time until you find your sweet spot.
Most of my big blocks have always liked about 34-36, but I used to have a 468 that only ran like it should've at 40....so you never know until you mess with it.
72' LWB Cheyenne
73' Camaro Z28/RS
70' Chevelle RagTop
00=ss=00
Rreemo is offline   Reply With Quote
Old 10-01-2009, 11:33 PM   #13
2tons of fun
Re: 454 Timing ?
wft are you turning the dist to 0?
when the motor is running the the line should run uphill to nearly straight up and down at heavy throttle.
i ran my old 454 at 24ish btcd too.
as far as the balancer goes, take the retaining bolt off and look at the keyway, it should line up with the timing mark on the outer ring.
2tons of fun is offline   Reply With Quote
Old 02-10-2010, 02:55 PM   #14
lyrikz
PITbut
lyrikz's Avatar
Re: 454 Timing ?
When you are setting the advance timing, what rpms do you want the engine at???
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-10-2010, 05:43 PM   #15
71 super
71 super's Avatar
Re: 454 Timing ?
My 402 likes to be around 16* btdc to run its best.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
