Old 02-10-2010, 11:34 PM   #1
SatisTraction
Cool 85 c10. what are the best fitting long tubes for a 6.0 swap?
I have searched and read for a week. some use the pace setters for the f body, some have tried doug thorley headers, some do the s&p headers.
I want the best fitting long tubes that i can get. I prefer some 1 7/8" primaries but 1 3/4" would work.
what headers did you use and with which engine mounts.
will truck headers fit?
thanks
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 02-11-2010, 08:45 AM   #2
78-5.3
78-5.3's Avatar
Re: 85 c10. what are the best fitting long tubes for a 6.0 swap?
thanks
Summit Racing SUM-G9048 truck header shortys 1 1/2 pri
Trans-Dapt Performance Products 4572 from summit
this has to be the most questioned thing about gen 3 conversions in these trucks
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 02-11-2010, 09:53 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
You could get a set of the big block full length headers and fit them with a set of LSx header flanges and modify a few tubes as needed like the third gen guys do.
http://www.summitracing.com/parts/SUM-G9011/
$90 for 1-3/4" tube full length headers designed for our trucks to start from.
I have seen the LSx flanges for $60 somewhere but don't have it handy. The GM ones are $52 each and are 3/8" thick so worst case you would still have under $200 into them.
I have a CAD file of the flanges and planned on getting a set water jet cut locally but if anybody on the board can do it I will share the file.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-11-2010, 09:28 PM   #4
Ceeten
Thats good to know. I really dont want to run the S&P headers. Dont care for the collector design. Would much rather have a true full length big tube with real collectors. You have any info on the mods needed?
Ceeten is offline   Reply With Quote
Old 02-12-2010, 09:53 AM   #5
68 TT
68 TT's Avatar
The big block & LS engines have very close tube spacings so mostly what is needed are to make some cuts in the tubes in a few places to bend the tubes into alignment with the ports of the LS header flange then weld them back together.
The cuts don't have to go all the way through the tubes only a little past 50% will allow them to be bent slightly for realignment.
Old 02-12-2010, 08:22 PM   #6
Ceeten
Thanks! Sounds like the way to go.
Old 02-13-2010, 07:45 AM   #7
SatisTraction
anyone that puts a 1 1/2" primary on a LS series engine should have left the old engine in there.
sorry but that is poor planning.
i have thought about the big block headers and may go that route. I have read about using f body headers and have a set lined up that i can use for mock up.
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
Old 02-13-2010, 09:56 AM   #8
78-5.3
78-5.3's Avatar
so your sayng leave the my tired 5.7 diesel because im using 1 1/2 primarys so then people should use standard manifolds right!!!
LOL sorry for poor planning ???
i cant stantd people stuiped replies!!!
Old 02-13-2010, 10:12 AM   #9
SatisTraction
i cant even understand what you are trying to say
i am saying that 1 1/2" primaries will hurt the performance of a 6.0L lsx engine and i have no intention of spending my hard earned $$$ to get less HP out of my combo. you do as you please and have fun doing it.
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
Old 02-13-2010, 10:36 AM   #10
78-5.3
78-5.3's Avatar
you said anyone that puts a 1 1/2" primary on a LS series engine should have left the old engine in there.
well mine was a diesel and tired at that !!so i converted it to the 5.3 are you saying i wasted money putting on my 1 1/2" shorty headers? that claim a %15 increase in power??
sorry if you dont understand what i typed but theres nothng wrong with runnng 1 1/2 primaries on a stock LSX engine!! its your personal preference to use larger primaries , i woundnt say usng the 1 1/2 inch primaries poor planning!!
Old 02-13-2010, 10:37 AM   #11
SatisTraction
well mine was a diesel and tired at that !!so i converted it to the 5.3 YouTube- 5.3 - 4L60E LSX VORTEC LS1 CONVERSION INTO 1978 CHEVROLET C-10
nice truck.
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
