layin frame what driveline
Im having a custom made triangulated 4 link with air ride put in my 62 chevy swb when done it should allmost lay frame will the stock two pice driveline pivot enough to lay out or will I need to put in a one pice ......
Any info would help alot |
On the fast track to nowhere..
Re: layin frame what driveline
Most bagged guys prefer the two piece shaft over the one piece. It will have enough movement and will allow you to do less cutting on your cab floor.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
100% gearhead
I like the stock 2 piece. It allows more than enough travel but the angle is steep to the pinion. Adapt the 63-72 2 piece and it works better because the rear half is longer.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
