Old 05-25-2010, 01:24 PM   #1
Tazfink
Tazfink's Avatar
Frame Swap Question.
I recently purchased a 1972 2wd C-20 frame supposedly from Az. Frame and trailing arms are in great shape. What do I have to do to mount my 66 C-10 body on it? Mounts Diff? Will 1/2 ton front suspension bolt upto it?? Thanks in advance.
"Rust does NOT look cool." - Me
"Patina is earned, not made." - Old Hot Rodder.
Cylinder Index
The Cylinder Index (or C.I.) is a measurement device in which the total number of internal combustion engine cylinders (working or non-working) owned by an individual (single-cylinder chainsaws, lawnmowers, 2-cycle, 4-cycle, multi-clinder diesels, trucks and farm tractors) are tallied. The Garage Logician who attains a C.I. in excess of his age is revered. - Joe Soucheray, Mayor of Garage Logic.
Tazfink is offline   Reply With Quote
Old 05-26-2010, 12:48 AM   #2
Captainfab
60-66 Nut
Re: Frame Swap Question.
The rear cab mounts are different. I'm not sure if the radiator support mounts are different or not. The front frame horns are different, and the '67-'72 frames don't have the forward crossmember that the radiator sits in like on the '63-'66 frames. Yes the C10 suspension along with the rear differential will all bolt up to the C20 frame.
Member ScotI is using a '68(?) frame under his '64 body. You might check out his build thread 'Project Recycle' in the Projects and Builds section on the '60-'66 forum.
Old 06-17-2010, 01:42 PM   #3
Tazfink
Tazfink's Avatar
Thanks for the info. I think I may try to use it on my 66, this will be a ways off.
Cylinder Index
