Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-04-2010, 01:02 AM   #1
americanmusc1e
americanmusc1e's Avatar
for all of the LSX non-believers.......
I was playing around in Desktop dyno (I know, the power figures are optimistic) the other day with different cylinder heads for my 383 to see how much hp I could gain without a cam change. (currently running vortecs). and the best heads I tested were AFR 195 Competition CNC Ported heads. (http://www.airflowresearch.com/index.php?cPath=24_29),
but in my travels on the internet I ran across the flow numbers for L92 (GenIV LSX) heads and decided to see what they would do on my 383 even though it is physically impossible to do...........Wow, I was impressed, you can get these for less than $1000 usually. LS motors have awesome head flow
here is a link to where I found the head flow info http://www.ls1tech.com/forums/genera...flow-data.html
NOTHING is changed except the head flow and the valve sizes
stock vortecs
AFR
L92
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-04-2010, 12:31 PM   #2
nomrlz
nomrlz's Avatar
Re: for all of the LSX non-believers.......
actually those figures are purdy dam close if you had the right cam in
nomrlz is offline   Reply With Quote
Old 03-04-2010, 01:12 PM   #3
shortbed70
shortbed70's Avatar
They make that motown motor that is a half breed of both.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-04-2010, 01:18 PM   #4
team39763
Yeah, there is a block that's out now that lets you put LSx heads on a regular smallblock style shortblock. I believe the point was cheaper bottom end parts, better oil system, badass LSx heads...sounds like it should be reliable and make tons of power. But I'd still just build a LS3 stroker or LS7 if I had the money.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 03-04-2010, 02:33 PM   #5
wheatlandbrawler
wheatlandbrawler's Avatar
merlin makes that block i think... the only problem is the money u spend on the block you lose the "cheap" rotating assembly ya know.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
