Old 03-14-2010, 01:32 PM   #1
k5kev
New Member
Barn Door Conversion Question????
Guys,
I'm converting from hatch and tailgate to barn doors on my 72 burb and it looks like there is no access to get any nuts and washers in to bolt down the upper door strike, rubber bumpers, and door sliders/checks.
What have you guys done? Sheet metal screws? Do you think the screws are going to hold everything tight?
Thanks, Kevin
k5kev is offline   Reply With Quote
Old 03-14-2010, 01:39 PM   #2
k5kev
New Member
Re: Barn Door Conversion Question????
..............What you you think about rivet nuts?
Old 03-14-2010, 01:47 PM   #3
Hart_Rod
Hart_Rod's Avatar
That's what I would do. You might want to do a test hole and see if the required plate is already there. You might get by with just drilling and tapping the correct size of hole....
Hart_Rod is offline   Reply With Quote
Old 03-14-2010, 01:52 PM   #4
Hart_Rod
Hart_Rod's Avatar
One of the mounting holes was already there on mine...
Old 03-14-2010, 07:28 PM   #5
olblue60@aol.com
member
Perhaps you could collect a couple more of the round plastic plugs that are common in the rear gate. Drill the holes for the strikeplate. Then drill a hole on the inside over each strikeplate location hole and slip the nuts in through the hole and tighten them up. Then put the plugs in the hole. I cut a slot in the strikeplate location and then filled the holes.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 03-14-2010, 08:52 PM   #6
PortHeadlight
PortHeadlight's Avatar
Does this picture help find the location you need. This is a 70.
PortHeadlight is offline   Reply With Quote
