Old 04-22-2010, 08:21 AM   #1
snoopy
snoopy's Avatar
Dropmember ?
What is the recommended front wheel width and back spacing for trucks with a dropmember?
snoopy is offline   Reply With Quote
Old 04-22-2010, 08:48 AM   #2
SCOTI
SCOTI's Avatar
Re: Dropmember ?
An 8-8.5" wheel w/5".00 would work well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-22-2010, 12:57 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
Re: Dropmember ?
What diameter wheel and tire combo do you plan on running?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-22-2010, 05:00 PM   #4
nastyc10
nastyc10's Avatar
Re: Dropmember ?
I'm running 20x8.5" with 4.5" backspacing. works fine for me. no rubbing with 70lbs of air which is a little less than I use at ride height. Some guys go with a little more backspacing.
nastyc10 is offline   Reply With Quote
Old 04-22-2010, 08:58 PM   #5
GVizzle
GVizzle's Avatar
Re: Dropmember ?
I'm running a 20X8.5 with a 5.25BS in the Front.
GVizzle is offline   Reply With Quote
Old 04-22-2010, 09:20 PM   #6
snoopy
snoopy's Avatar
Re: Dropmember ?
It's going to be a 26" rim. I don't know the rim width or the tire size yet, but I do know the overall height will be 31-1/4".
Old 04-22-2010, 10:02 PM   #7
mullit
mullit's Avatar
Re: Dropmember ?
how about a 265 35 22 on a 22 by 9 inch wheel? or may be a 305 40 22 which i could get a real sweet price on tires, on the 22 by 9's on a 90 burb
mullit is offline   Reply With Quote
Old 04-22-2010, 10:20 PM   #8
SCOTI
SCOTI's Avatar
Re: Dropmember ?
Originally Posted by snoopy View Post
It's going to be a 26" rim.... the overall height will be 31-1/4".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-23-2010, 11:57 AM   #9
duceducenine
duceducenine's Avatar
Re: Dropmember ?
can anyone tell me the track width with stock style a arms?
duceducenine is offline   Reply With Quote
Old 04-23-2010, 12:34 PM   #10
edflores
Re: Dropmember ?
What size tire would that be?
I think ill be at that size with some rubber band 24's so im most likely going with 22 in front to be safe
edflores is offline   Reply With Quote
Old 04-23-2010, 11:15 PM   #11
SCOTI
SCOTI's Avatar
Re: Dropmember ?
I recall seeing 64.5" front disc brake track width. Pre-71 trucks were 62" rear width; post-71 were 64-ish (wheel mounting surface to wheel mounting surface).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-24-2010, 04:06 AM   #12
duceducenine
Re: Dropmember ?
is that stock? or drop member track?.....?
reasoning i want to sub frame a 57 with 73.....
Old 04-24-2010, 09:25 AM   #13
SCOTI
SCOTI's Avatar
Re: Dropmember ?
That's stock track width..... DM track width would be 62" from memory.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
