Old 03-25-2010, 10:36 PM   #1
bigwheel15
bigwheel15's Avatar
Identify this part/its purpose
What exactly does this thing pictured do? Whats it for?
bigwheel15 is offline   Reply With Quote
Old 03-25-2010, 10:39 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Identify this part/its purpose
That's your cruise control transducer, Without it your cruise won't function.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-25-2010, 10:42 PM   #3
bigwheel15
bigwheel15's Avatar
Thanks, and actually my cruise doesnt work anyways. So what would I have to do to remove it from there? Im guessing those two screw on cables are for the speedometer?
Old 03-25-2010, 11:48 PM   #4
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
yeah its your speedo, on cable goes from your cluster to that piece, and that piece to your tranny. if you remove it you might have to get a new speedo cable
staggerd86c-10 is offline   Reply With Quote
Old 03-25-2010, 11:49 PM   #5
bigwheel15
bigwheel15's Avatar
Figured as such, guess ill add that to the list for when I head to the junkyard this weekend.
Old 03-26-2010, 12:37 AM   #6
spinem
haha, ford guys...
does the cruz controll mantain costant speed??
(if its set at 55.. will it go 55 up hill?)
spinem is offline   Reply With Quote
Old 03-26-2010, 02:23 AM   #7
FLEET72
FLEET72's Avatar
A properly functioning one will.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-26-2010, 02:49 AM   #8
love my 72
love my 72's Avatar
So is it safe to assume the same if you go down hill?, provided you don't hit the brakes first and activate the vacuum disengagement.
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
Old 03-26-2010, 05:15 AM   #9
S10Fan
Old Heap Driver
Yes,unless the hill/mountian has a ski ramp style drop. LOL
BTW...I added a cruise unit from Dakota Digital on my truck, LOVE it, especially on long trips.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-26-2010, 07:30 AM   #10
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
That is an after market, I believe, it might work if you hook up the missing vacumm line that is off in the picture. There should be some parts on the carb linkage too, it looks very similar to the one I took off my truck after I bought it. Mine even had a sensor on the drive shaft.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 03-26-2010, 09:48 AM   #11
menace121978
menace121978's Avatar
Sorry Jeff, but that is factory. i highly doubt it will work even with the vaccum line hooked up. they are known to go bad and not hold a steady mph. there is a rubber diaphram inside that goes bad over time.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 03-26-2010, 11:19 AM   #12
C10Silverado79
Is it worth trying to fix the factory CC? Mine tries to work but cannot hold the mph. It slowly decels.
1979 C10 Silverado
1998 Camry 5spd
2005 Harley ElectraGlide
C10Silverado79 is offline   Reply With Quote
Old 03-26-2010, 11:32 AM   #13
menace121978
i wouldnt... i replaced mine twice. even when it was working it left alot to be desired. if i was to do it again i'd just use the dakota one like Bryan(S10Fan).
"Dennis the Menace"
Old 03-26-2010, 11:34 AM   #14
Cherub
Cherub's Avatar
yea i chunked mine in the rebuild
Cherub is offline   Reply With Quote
Old 03-26-2010, 12:35 PM   #15
TexasJeff
TexasJeff's Avatar
Opps, sorry for the misdirection, mine looked similar but was for sure after market.
TexasJeff
Old 03-26-2010, 03:20 PM   #16
kevinr1970
Any idea of what that set-up cost?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-26-2010, 03:46 PM   #17
C10Silverado79
Does the Dakota unit use a similar in/out connection for the speedo cable or do you have to add some other modification?
1979 C10 Silverado
1998 Camry 5spd
Old 03-26-2010, 06:37 PM   #18
FLEET72
FLEET72's Avatar
Just one dealer's: http://www.phoenixtuning.com/zenstor...FQlLbQodwWkzBA
Cable Driven Speedo
Electronic Speedo
Oscar
'95 Jimmy 4X4
Old 03-26-2010, 07:23 PM   #19
S10Fan
Old Heap Driver
Seems like I paid around 300.00 for both the unit and a "pass through" generator. The sender for my electronic speedometer wasn't strong enough so the pass through unit was required.
Bryan
Old 03-26-2010, 07:25 PM   #20
S10Fan
Old Heap Driver
You'll need some additional parts. I'd call Dakota Digital, they were very helpful with my install.
Bryan
