I was just wondering how the ignition modules with different numbers of pins work differently? The 4-pin modules are pretty self-explanatory (pickup coil input, output to coil), but on the other modules there's a connector wire that goes into the cab through the firewall - why?
'71 Custom 10 350/TH350/3.73 Holley 650 Dbl. Pump, Headers, HEI ***************************** '76 K10 350/TH350/205/12-bolt(R)/Dana44(F) Primer Gray! ***************************** '01 Grand Prix GTP - my 260 HP gas sipper! Victory Red |
the two are different the 5 pin is without a computer and the 7 pin is with a computer. that is computer controled . a CCC or a C4 system
You get what you pay for
![]() Join Date: Dec 1999
The 5 pin module is for distributors with the ESC (Electronic Spark Control) system. This is the one that has the wires going through the firewall.
The ESC distributor plugs into a control module behind the glove box. All the ESC does is control spark knock. You will notice the knock sensor screwed into the block in front of the starter. I have replaced all the mess on my truck with an MSD Pro-Billet HEI distributor. Hope this helps, ------------------ Mike 1985 Chevy C-10 Mike's 73-87 Chevy Pickup Site
Mike 1985 Chevy C-10 |
![]() My ESC control box is near the accelerator pedal, mounted in a free-stand-up position. This is in the 81... |
