Old 04-09-2010, 03:10 PM   #1
glendale
glendale's Avatar
67-70 rear end
will a 70 rear bolt in to my 65? mine is about to go and i found one on cl for 60 bucks.it's only the rear do i need anything else?i plan to put my brakes on it. and my truck is a factory 283 powerglide what gears do you think i have? the new one is a 3:08.thanks in advance..
glendale is offline   Reply With Quote
Old 04-09-2010, 03:35 PM   #2
Bugeyev8
Bugeyev8's Avatar
Re: 67-70 rear end
I believe it will bolt right in, I think you would be better off with the later brakes, the powerglide had a 2.70 something ratio as I recall
Bugeyev8 is offline   Reply With Quote
Old 04-09-2010, 03:46 PM   #3
Russ65C10
Russ65C10's Avatar
Re: 67-70 rear end
2.70? mine came with a 3.73.
block up your rear end and rotate the wheels to see what rear end gearing you have. I read some where around here that the number of times your drive shaft rotates for one rotation of your wheel ='s your gearing.
I also think I've heard the 67 ups are little wider due to the brakes but I could be wrong.
Russ65C10 is offline   Reply With Quote
Old 04-09-2010, 04:07 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 67-70 rear end
While a 70 rear end will bolt in and work, it is wider then the one coming out of your 65. The 69-72 rear end is wider then the 64-68 rear ends. I have also seen differences in where the pan hard bar mounts to the rear end. I believe that the 65 and 70 use the same mount, it is a stud on an ear cast into the center section on the passenger side.
Double check that the brake shoes and drums are the same. Some trucks had wide shoes/drums.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-09-2010, 04:11 PM   #5
glendale
glendale's Avatar
Re: 67-70 rear end
ok cool thanks guys. i think for 60 bucks i will just grab it.
Old 04-09-2010, 06:04 PM   #6
chevroletrestoguy
Re: 67-70 rear end
My 65 has a 70 rear end in it. It will work fine. It is 3/4" wider on each side (1/1/2" wider all together).
chevroletrestoguy is offline   Reply With Quote
