throttle rod to cable
I have a 70gmc that came out with a rod operated throttle. my bracket on the firewall that hold the pivot rod in cracked and i cant seem to find a replacement.
I noticed 71-71 had cable according to lmc. how hard or is it possible to convert a rod operated cab over to a cable operated? Thanks in advance |
Re: throttle rod to cable
In 71 they went to the cable and it involved modifying the firewall for the mounting bracket. You can massage your firewall or weld in a section of firewall from a 71-72.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
If I'm not mistaken there is someone on here who makes a 71-72 pedal conversion for the 67-70 trucks that makes it a direct bolt on. I'm sure someone will chime in.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
blood type; Retumbo
Between Trucks...
http://67-72chevytrucks.com/vboard/s...d.php?t=371099
http://67-72chevytrucks.com/vboard/s...00#post1383300
Beat it to fit, Paint it to match... ![]() |
