Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 03-29-2010, 04:11 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
WTB Blazer Front Buckets & Hardware
Looking for front buckets for 1969 Blazer plus all mounting hardware.
Baketown Scotty is offline   Reply With Quote
Old 03-29-2010, 04:51 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: WTB Blazer Front Buckets & Hardware
Here you go:
http://www.67-72chevytrucks.com/vboa...d.php?t=392248
Hart_Rod is offline   Reply With Quote
Old 03-29-2010, 05:35 PM   #3
sharpie1972
Are you looking for utility buckets or sport buckets and console? I have both and can send pics. Thanks, Sharpie
sharpie1972 is offline   Reply With Quote
Old 03-30-2010, 07:50 PM   #4
Baketown Scotty
Junior Member
Hart Rod - I am only intereted in the fron buckets. Seems a little rich for me even though they look to be in great shape. Willing to sell only the fronts w/o console?
Sharpie - I prefer the sport buckets but a lot hinges on my budget. Would like to see your pictures.
Old 03-30-2010, 08:38 PM   #5
Hart_Rod
Hart_Rod's Avatar
I really don't want to separate them.
R/
Old 03-30-2010, 09:16 PM   #6
lks dcvn
lks dcvn's Avatar
69-70 and 71-72 have different brackets to mate up with the floor so be sure you get the right ones to match your floor...
lks dcvn is offline   Reply With Quote
Old 04-15-2010, 01:01 PM   #7
anythingonwhlz
Thats is correct, I tried to put a nice set of front buckets from a 72 4x4 K5 into my 1970 2wd and bolts didnt line up. The 72 seats also makes you sit up alot higher.
1963 409 Impala
2009 HD Roadglide
1970 396 2wd Blazer
1972/67 Bagged 2wd Blazer
1968 396 2wd Panel
1972 396 2wd Short/step
1996 4wd Bagged Tahoe
anythingonwhlz is offline   Reply With Quote
Old 04-18-2010, 10:43 PM   #8
67/72junkie
If they made you sit higher they were 73 up blazer mounts.I have 69 70 71 72 and all the mounts are the same.I have more than 10 sets cst bucket from 69/72 trucks and blazers and all the driverside mounts are the same.I looked at utility buckets last week and the mounts on them were the same as bench seat.If cst bucket mounts do not bolt directly to your floor your blazer came with utility buckets.The 73 up mounts have the same bolt pattern as cst buckets but the mounts are 11/2'' taller in the front and 1/2'' in the rear and make the seat lean back slightly.You can remove the lower foot on the front of 73 up and replace it with the foot from a 72 bench seat mount .It is the same as 72 bucket mount.This will lower the front 1'' and make the mount sit level and it will be 1/2'' taller than factory 72 cst bucket mount.I have pics of all mounts and the mods if needed.
67/72junkie is offline   Reply With Quote
Old 04-23-2010, 11:43 AM   #9
Baketown Scotty
Junior Member
Sharpie1972 - DOes a console only fit between the sport buckets? I have a console and just need the two seats. How much for the utility seats? Sport buckets? Pictures?
