Old 06-04-2010, 12:15 AM   #1
wzuke
wzuke's Avatar
383 kit and Procomp heads
Has anyone used the 383 rotating assembly kit and/or Procomp aluminum heads from Skip White? If so, I would appreciate your comments pro or con.
wzuke is offline   Reply With Quote
Old 06-04-2010, 03:07 AM   #2
tim21391
tim21391's Avatar
Re: 383 kit and Procomp heads
i am running pro comp heads on my 347 stroker that im building hasnt been put in car yet so im also wanting to know pros and cons on the heads
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-04-2010, 06:35 AM   #3
JMac11
JMac11's Avatar
Put one together for my brother, he bought block, crank assembly and heads from Skip White. Everything checked out great, runs good. Only problem, go ahead and have them notch the block if you get one for the crank and make sure to get a oil pan that will clear the stroker crank. He put it in an 85 Monte Carlo SS, street car runs 6.90's in the 1/8th.
JMac11 is online now   Reply With Quote
Old 06-04-2010, 07:53 AM   #4
au03z71
au03z71's Avatar
I honestly haven't heard much good about out of the box ProComp heads. There are a few success stories, however, where people have had porting and polishing done to them.
au03z71 is offline   Reply With Quote
Old 06-04-2010, 09:51 AM   #5
Sinister
Between Trucks...
Sinister's Avatar
I haven't heard many good things about Procomp heads. The rods they use on their stroker kits are questionable, if they are the same Procomp ones they were using a few months ago. They do have good prices on Scat cranks though.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-04-2010, 03:13 PM   #6
tim21391
tim21391's Avatar
im using pro comp rods
Old 06-04-2010, 03:15 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
I was looking at those stroker kits and Googled the kind of steel those rods are made out of compared to Scat rods. They're not as strong a steel.
Beat it to fit,
Old 06-04-2010, 03:57 PM   #8
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
I bought a set of those ProComp heads and not sure if any of you guys had any issues. But when I sold them to a friend of mine he wasn't too happy.
What it was, in the center head bolts you had to file down the valve spring washers. So I would hope that have addressed this issue and fixed that problem. But other than that, they seem like good heads for the money.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
