64 c-10 rear dualie
does anyone know someone that sells a kit? or will a c-30 rear end fit up to the stock c-10 trailing arms? any insight would be great!
![]() Join Date: Nov 2003
Re: 64 c-10 rear dualie
With some work it will fit. Do you have the rear?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
i do not, but i know of one, i wanted to know before i bought it, right now i have a twelve bolt coil spring 64 c-10 what would i have to change
1961 crewcab
all the c 30's were leaf spring rear, that said you could cut the pads off your coil setup, and make a panhard bar mount for the c 30 rear.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
given some good steel, and a few good friends i could set one up with the right angles to mount right up to my trailing arms right? and then on that note, how long is the c-30 with tires and all, what type of rear end does it use, and also what is the lug pattern
If swapping a later year dually rear housing, what diameter are the axle tubes? That might be an area of concern & prevent a 'bolt-in' swap. If the axles tubes are larger (3.5" vs 3"), the truck arms might need to be custom built for the addiditional width (3.5"w u-bolt isn't going to fit where a 3" u-bolt fits).
Watch out for your cornhole !
![]() Join Date: Jun 2003
You'd be much ahead to just install a coil spring type of 3/4 ton 8 lug rear end and dually the tires from there.
That way you don't have to mess with welding on trailing arm mount pads or panhard bar mounts. It gives you a bolt in 8 lug bolt in rearend. From there the dually swap is easy.
#8 | |
Longer wheel studs, 1/2 inch thick spacers and you're done.
So the inner wheel mounts like a standard wheel against the drum/axle flange. The .500" spacer goes on top of the 1st wheel & then the 2nd/outer wheel slips on. Tighten eveything & that's it on the dually conversion?
No, it's the other way.
Brake drum, spacer, wheel, wheel. The inner wheel's cup shape will slightly interfere with the fins around the brake drums. The 1/2 inch spacer puts it out far enough so the wheel clears the drum fins.
Just to add, some of the 3/4 ton rearends needed this, but others need no spacer and they clear fine. Apparently some use slightly different brakes. I've done it twice, one needed spacer, one didn't.
Ahhh.... I figured the duals butted against each other in a standard dually application & was thinking there was some reason they couldn't in a swap application.
Would this be the same width as the standard dually housing or the 'narrower' C&C?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-08-2010 at 01:17 PM. |
i know of a c-10 or c-20 with a dually conversion, said it was made by a one rick o'doul? any insight, i took another look today and it looks like it was just a 7-8 inch spacer from the other tire with longer "rods" for my lack of truck vocab. and then just a regular tire(?) i think. ill see if i cant snap a photo sometime soon.
#15 |
the spacer was all connected and the "lugs"(aka rods in earlier posts) just went trough it, like a circle, with smaller circles surrounding this main circle( molded into itself) and the lugs went through the smaller circles, its a very interesting idea, any one know how i can do this?
#16 |
60-66 Nut
So if I understand correctly, you want to convert your '64 C10 to a dually? Are you trying to keep the wheels inside the bedsides or fenders? Is your truck a fleetside or stepside? I agree with Tx Firefighter that just using a '72 and earlier C20 rear end would be an easy swap, and then just add the dual wheels as he described. Switching to a '73 and later dually rear end, be it a 14 bolt or a Dana 70 may be doable, but I'm not sure about the U-bolt issue. I'd have to check on that.
#17 |
There is a truck near me that appears to be a 60-66 dually. It's back off of the road a little so I haven't been able to get a really good look at it, but it appears to be pretty nice.
64 Stepside.. A work in progress.. ![]() |
#18 |
go sneak a look! haha but ill try to take photos for you guys to see what this kit looks like, its def a 1/2 ton. and it is a fairly straight forward kit, its the "same" truck as mine, 1/2 ton long bed fleet side
#19 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
There's the setup you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=400953
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#20 |
yes it is!
