Carpe manana
![]() ![]() Join Date: Dec 2010
Where does this bracket attach? 71 manual throttle
I’ve searched the FAM and combed old related posts but cannot find any guidance on where the small bracket specific to the 71 manual throttle option bolts to. Any guidance and photos would be a big help. Thanks.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Where does this bracket attach? 71 manual throttle
I will have to look, but if not mistaken, it bolts on throttle bracketand catches the cable as it moves to pedal extension. If I remember correctly it catches one of the three hole at top of main bracket
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Carpe manana
Thanks. The holes on the throttle bracket seem to small to accommodate the accompanying bolt but that arrangement seems sensible. Pics if possible please.
![]() Join Date: Jul 2016
It bolts to the brake pedal assembly, forward bolt i think, or above it, someplace on it in that area.
http://67-72chevytrucks.com/vboard/s...d.php?t=783035 |
Carpe manana
Thanks Randy. I’m surprised there’s no previously posted detail pic of where the small bracket mounts let alone showing the routing between the ducts for 71 as the mount is shifted sideways much more than the 72 example.
There is a factory assembly manual type drawing out there of how it fits together, i cant find it now though.
I also looked at my pedal assembly and cant figure out how it mounts. I bet classic bowties knows how it mounts and has pictures. |
I bet you have to drill a hole like you have to drill a hole in the brake pedal for cruise control vacuum switch on the pedal.
Carpe manana
Doh! Am hoping it’s just a straight forward bolt in.
![]() Join Date: May 2010
Info from long ago... May help. Read another regarding cable routing over the wiper motor and down.
Start at post 59. https://67-72chevytrucks.com/vboard/...hrottle&page=3
Jim Last edited by FirstOwner69; 04-11-2020 at 05:33 PM. |
Carpe manana
Jim thanks. Almost. I’ve got same question as badpeanut but don’t see it was addressed on that thread (https://67-72chevytrucks.com/vboard/...3&postcount=61).
#11 | |
I figured that would be the case but was hoping you would spot the piece in the photo in post 59 even though I couldn't.
Jim |
It's not the piece I marked below, is it?
Jim |
Carpe manana
It’s not. That part of the larger bracket. The smaller one I suspect is just outside the field of view but the picture does show the trajectory of the throttle cable as it “lands” on the pedal and gives a clue. It’s got to be on the brake pedal assembly as Randy mentioned but a photo clarifying orientation would be helpful.
The pictures in this link may provide a clue. They show that bracket attached to the cable. That bracket must attach to something above. Could be the brake pedal assembly as you suggest.
http://67-72chevytrucks.com/vboard/s...17&postcount=5
Jim |
#15 |
Jim |
#16 | ||
Carpe manana
Mels post is the one got educated me that a difference existed for 71 vs 72.
#17 |
![]() Join Date: Nov 2016
Just another example of routing with the little bracket on the 1971 setup.
1987 V30 Silverado SRW 454/400 4x4 104k 1979 GMC C3500 Sierra Classic 3+3 454/4l80e 1971 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=804580 https://67-72chevytrucks.com/vboard/...d.php?t=837441 https://67-72chevytrucks.com/vboard/...92#post9355392 |
#18 |
Carpe manana
That's it! The missing piece. Thank you sir. I bet the cable runs left of the wiper motor not right of the motor as for 72.
#19 |
Finally a picture.
Just as i thought, requires drilling. Now the question is, do both holes on the bracket get a bolt or just the one pictured. |
#20 |
Carpe manana
The visible bolt is an existing one on the pedal bracket isn't it?
FWIW several I've seen offered for sale over the years have a bolt at each hole.
#21 |
I only have 72’s here, checked 3 and none have a hole for either location.
#22 |
Carpe manana
I peeked updash in my Blazer last night - may have mistook a bolt for the one here. Will look again.
