Replace turn signal lever with multi-function stem?
I haven't found anything with a search so does anyone know if you can retro-fit a multi-function stem like this to and older truck or do you have to swap out the steering column to make it work? I'd like to get the wiper functions up off the dash board.
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide |
I really hate wet sanding!
![]() Join Date: Dec 2008
Re: Replace turn signal lever with multi-function stem?
I think it would be easier to swap collumns. Get one from the salvage yard and when you remove it, get all the plugs that attach to the column with as much extra wire attached to those plugs as possible. Then you are going to have figure out how to wire the new pigtails into your current harness. You will be able to eleminate the floor mounted dimmer switch as well. You may run into probs on the wipers, I am not sure if the wiring is the same between post and pre 80 trucks and am sure it is different if you try to add on intermittent wipers..
Good Luck!
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
#3 | |
In the Forgotten far North.
![]() Join Date: Jul 2007
Keep the floor mounted dimmer switch in place and wire it up as an ignition interrupt switch to keep any would be dirt-bags from driving off with your ride.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
