Old 05-30-2010, 02:32 PM   #1
ehuth1
Centerbolt Valve Covers and Gaskets
Does anyone have any tricks to get these in? I've tried setting them with adhesive to stay put until tightened. I've tried setting them on the head then wiggling them into place under the valve cover??? Am I missing something here, because this is just ridicoulous...
Any help is appreciated.
ehuth1 is offline   Reply With Quote
Old 05-30-2010, 03:06 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Centerbolt Valve Covers and Gaskets
Haven't had to deal with centerbolt valve covers, but I would stick the gasket to the valve cover with a thin layer of RTV or Gaskacinch. Let dry and bolt em up.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-30-2010, 03:19 PM   #3
scooterskoolkustoms
scooterskoolkustoms's Avatar
There is a right side and a left side.do you have them on the right way?
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 05-30-2010, 03:27 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I've always used RTV to glue the gasket to the cover...let dry...then just a little oil smeared on the bottom side of the gasket and bolt it up.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-30-2010, 03:59 PM   #5
ehuth1
I'll try some rtv and I think the gaskets are identical just from laying them on top of each other. The instructions claim they stretch to fit??? Whatever that means.. They are like a quarter inch off on each side but when stretched that fit perfect, but won't stay.
Old 05-30-2010, 04:10 PM   #6
1949gmc
I was having this same problem last week. This is my first time dealing with centerbolt covers and the FelPro stretchy gaskets. I found that stretching them onto the valve covers first and then holding them on all four corners with my fingers worked. Once you get the gasket held in place with your fingers, put the valve cover on the head very carefully, slipping the ends of your fingers out from under the gasket just before the cover/gasket actually touches the head. Hold them down with your hand until you can get a bolt or two tightened down so that the gasket doesn't slip out. Not sure how easy this will be reaching over the fender and under the m/c: my engine was on the stand when I did this.
1949gmc is offline   Reply With Quote
Old 05-30-2010, 04:21 PM   #7
Arad68
Trucks N Tranzams
Arad68's Avatar
There is a left and right side to centerbolt valve covers and heads. Aftermarket valve cover manufactures often miss these things during their R&D. The difference is slight.
I lined up and adhesed the Felpro blue "stretchy" (neoprene) gaskets to the valve covers and cranked them down using ARP hex head bolts. Be careful not to tighten them so much that you crack the covers or the head.
Thats a good looking engine you have.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-30-2010, 04:28 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have always used Gasgacinch to "glue" the gaskets to the valve covers. Put a light coat on the cover, and a light coat on the gasket. Let it dry a little, and stick the gasket on the cover. It won't budge... I do this whether they are the center bolt variety ot the perimeter bolt variety.
If the gaskets are the neoprene type with the steel insert... then I go real light on the Gasgacinch.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-30-2010, 04:31 PM   #9
GASoline71
GASoline71's Avatar
On a different note... is that vacuum line going from the bottom front of the carb going back to the vauum advance on the distributor? If it is... you should cap that on off on the front of the carb and use the "timed" vacuum port off of the metering block on the passenger side of the carb.
Gary
Old 05-30-2010, 05:17 PM   #10
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Thats what i was thinking.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 05-30-2010, 07:18 PM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
I use Permatek Form-A-Gasket (red gasket sealer). It is great for setting gaskets to the valve cover and then after it sets up put them onto the heads.
Frank
Old 05-30-2010, 07:35 PM   #12
ehuth1
Tried for 2 hours... Its tough with the engine in the bay! I'm going to walk away and try again tomorrow. Thanks for the ideas though!!!
Old 05-30-2010, 07:48 PM   #13
GASoline71
GASoline71's Avatar
Gary
Gary
Old 05-30-2010, 10:20 PM   #14
hayhauler71
hayhauler71's Avatar
If you are using cheep chrome covers I have found that the ridge on the cover that holds the stretchy gasket on is not as tall as the OE covers and they want to fall off. If you use the covers I would glue cork gaskets to the cover than install.
hayhauler71 is offline   Reply With Quote
Old 05-30-2010, 11:12 PM   #15
1949gmc
I was wondering about this as I don't have a pair of OE covers to compare to. Mine say 'Made in Taiwan' on the inside and I thought that maybe the ridge wasn't tall enough. What did I expect for $63 bucks.
Old 05-31-2010, 06:19 AM   #16
jim zag
ENGINE BUILDER
jim zag's Avatar
The aftermarket valve covers do not grab the gaskets the way OEM covers do. I buy Victor gaskets because they have little nubbies along the length that help hold them in place. I also use mineral spirits solvent to make the gaskets SWELL UP. Be careful because you can make the gaskets expand TOO MUCH!!!!! You might also try ADJUSTING the covers around the corners with a HAMMER! GO EASY!!!!!
JIM ZAG
jim zag is offline   Reply With Quote
Old 05-31-2010, 11:45 AM   #17
ehuth1
Has anyone used these?
http://www.summitracing.com/parts/FPP-1648/
These I'm assuming do not stretch and fit perfect in the valve cover. Any advantage to the cork/lam?
Old 05-31-2010, 12:20 PM   #18
KSCHEVYUP
KSCHEVYUP's Avatar
This may be a little off topic;
But on the subject of center bolt valve covers;
I have a set of aftermarket heads that have the holes to mount up either the center bolt valve covers or the old style perimeter bolt covers.
Do you have to use special offset rocker arms to use the center bolt covers or are the original style rockers going to have enough clearance for the center bolts?
Ron
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 05-31-2010, 02:10 PM   #19
LONGHAIR
Gary
I am not entirely sure what this is about...and why you felt the need to repeat it? Especially since, in the opinion of most (including me) that this is wrong.....but, it does matter how the distributor is calibrated. You can't just go swapping that vacuum line around. It has to be connected to the proper source for the way the advance curve is set.
IMHO, that means full vacuum and the distributor calibrated to match.
Ported vacuum sucks....no pun intended. That is out-dated and badly engineered "technology". It was bad when it was "new", so we don't want to keep carrying it along. It was a bad attempt at emissions reduction, which killed performance and wasn't so great for economy either.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-31-2010, 03:01 PM   #20
GASoline71
GASoline71's Avatar
Uhh... no sweat... never mind then... I'll just be old and outdated.
Apologies to the OP if it was a derail...
Gary
Old 05-31-2010, 05:15 PM   #21
LONGHAIR
It was never right when is was "new"......
Old 05-31-2010, 05:44 PM   #22
GASoline71
GASoline71's Avatar
I guess I need to check this out then... I've always had the vac advance hooked up there.
If it's been dicussed on here... I'll do a search...
Gary
Old 05-31-2010, 08:17 PM   #23
hayhauler71
As from my last post that's what I would use.
