![]() Join Date: May 2006
anyone know heads
Picked these up several years ago for a good price (50 bucks), partial casting number is 2183, center bolt
Now that I have problems with my original heads I would like to use these Engine is a 70-80 years(I'm not good at figuring out the stamped numbers on the block) 305 or 350. Heads seem to bolt up, although 2 seem to be shorter, angle on the manifold looks good. I don't know if the oil and water passages line up Any thoughts?? Thank you for looking ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-16-2010 at 01:22 PM. |
Re: anyone know heads
Those are 87-95 style 350 TBI heads. You can use them with no problems on a older model block, but you will have to slot your intake bolt holes.
Well Thank You for the info, that's great! I'll make sure to pay attention to the mounting holes on the intake. Any idea on the lenght of the pushrods, same as my old heads? Are the rocker arms 1.5 ratio?
Yep, you're right! Mounting bolts need just alittle bit of work
Pushrods should be the same as long as you're using a flat tappet cam. Hyd. Roller will use a shorter pushrod.
