Old 08-23-2010, 11:19 AM   #1
BAYB
lowering 1972 lwb
Has anyone ever lowered a1972 lwb pu with 15x10 wheels and 295/50 tires? If so, how low and what method.
BAYB is offline   Reply With Quote
Old 08-23-2010, 11:56 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering 1972 lwb
A 3"/5" spring drop would be the cheapest.
The front won't go much lower with a 15x10 wheel.
Keith
Convert to disc brakes.
Old 08-23-2010, 12:31 PM   #3
BIG ORANGE
BIG ORANGE's Avatar
Welcome to the board from SC.
There's a few ways to go about lowering your truck from cheap to not so cheap!lol
I've lowered alot of these truck buy simply cutting 1 complete round out of the bottom of the front springs and making up a set of 2" blocks for the rearend and that will put you at about a 2" drop on all 4 corners and have your truck setting level also.
The other option is to buy 2 1/2 drop spindles and drop springs for the rear.
Depending on the drop you want you can also buy drop springs for the front to go with the spindles, I would'nt advise going any lower than a 2" spring up front because the shorter springs drops out of the spring bucket when the truck is being jacked up!
jmo..........
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 09-01-2010, 04:22 PM   #4
BAYB
Thxs
Old 09-01-2010, 04:50 PM   #5
nbpro
we cut the front coil springs 2" drop and move the rear leaf hanger bolts up 3" drop ON 81 THO see post 11 http://67-72chevytrucks.com/vboard/s...d.php?t=359363
where we got the idea
nbpro is offline   Reply With Quote
