Old 06-10-2010, 05:16 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Where is the rain coming in ?
We have a lot of rain this spring and a couple of times after a good soaker I have found a little water had dripped down on the upper sloped part of the passenger side floorboard. I'm thinking its coming from the windshield as the seal is older, does that make sense or is something else leaking?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-10-2010, 06:37 AM   #2
292farmer
292farmer's Avatar
Re: Where is the rain coming in ?
sounds right, one way to locate it(not that u want more water in your truck) take a garden house and douse the suspected area if it leaks you've found the spot, could be i know on mine my antenna is crap and its mounted on front pass fender and it leaks pretty bad haven't seen to much get in the cab , but could be another spot to check
292farmer is offline   Reply With Quote
Old 06-10-2010, 06:40 AM   #3
cdowns
cdowns's Avatar
common leak areas are the cowl vent flap and also the rain gutters if the sealant/weatherstripping is dryied out and cracked wiwill allow leakage
Old 06-10-2010, 06:52 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
what about the hole in the cowl where the antenna cable passes through?
68C15 is offline   Reply With Quote
Old 06-10-2010, 10:38 AM   #5
pat 70/71
pat 70/71's Avatar
I had a truck that po parked under the same tree for ten years. (non runner) I had water coming in the cab pass side. the cowl pull vent was full of leaves/ other trash ( to the bottom of the vent) hope this helps, Pat
pat 70/71 is offline   Reply With Quote
Old 06-10-2010, 10:51 AM   #6
mdwilf
mdwilf's Avatar
If I understand correctly, the water is dripping on the floor where it slopes up towards the windshield - if so, I'd bet it's a leak around/in the heater box.
What I do in my spare time:
http://rosebudsgarage.shutterfly.com
mdwilf is offline   Reply With Quote
Old 06-10-2010, 11:18 AM   #7
Sinister
Between Trucks...
Sinister's Avatar
I'd pull the cowl and take a peek. I had a leak in the same area. Was both the windshield seal and cowl.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-10-2010, 04:26 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I had bad rust in my cowl, some kidna duct that forces the air out, its like 3 pieces of metal come together perfect for rust lol im workin on cuttin it out its PITA
John
1999 Toyota Tacoma 4x4
Old 06-10-2010, 04:36 PM   #9
60ratrod
yes, i do
60ratrod's Avatar
my guess would be the cowl as well. on my recently re-aquired 72 my glove box area(not that it had the liner in there to begin with when i got it) would constantly be moist and i kept a haynes manual in there and its got the wet look to the pages. my other guess would be around the windshield
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 06-10-2010, 05:17 PM   #10
Already Gone
Thanks for all the replies. I do have a new windshield rubber and plan to change the windshield as well. I did take the vent cowl vent off a year or two ago and cleaned it all out and put some screening underneath it to catch the leaves. The drips are on the slope part about half way between the hump and the passenger door.
I haven't driven the truck much the last two summers and this year decided to drive for a few months and all it has done around here is have record rail falls.
Old 06-10-2010, 10:31 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I'm sticking a pic of my firewall in so you can see what will happen if you let it leak and use the wrong stuff to stop the leak.
But, the first thing to leak is the plenum area at the kick panels. There's no drain from the factory and it fills up with dirt, leaves, etc. This is the rust that you see on the inside of the cab at the vent doors. It is the most common source of water leaking into the cab.
But, because of this situation on my '69, the P.O. used some non-automotive silicone sealant, which reacted with the steel (over several years) and caused some serious cancer. He started daubing the stuff anywhere he figured the water might come in. He put a ring of it around the wiper motor mounting (and the wiper motor ass'y fell into the cab), as well as built a dam with the sealant in the area over the heater/ac box on the firewall.
Here's a pic. Don't use the wrong silicone sealant. This is the result.
Member Nr. 2770
Old 06-11-2010, 01:24 AM   #12
tim21391
tim21391's Avatar
if it is the windshield those are easy to replace the gasket.. i took a box cutter knife and cut my old gasket to get the windshield out.. then you fit the knew one on the windshield while its sitting on the saw horses or something then set windshield on truck then on inside use like a 90* bend and pull the gasket threw.... just my .02
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-11-2010, 01:56 AM   #13
Already Gone
Thanks for the tips. I have insurance for the windshield with a 50.00 deductible and I also bought the chrome/aluminum insert that goes in the gasket. I will leave it to the pros to install the gasket and moulding.
Old 06-11-2010, 02:07 AM   #14
nuke1
nuke1's Avatar
when he says alot of rain latley, he means it, at the farm 1.5 hrs south of saskatoon, we have gotten roughly 15 inches in the last month, the crop is not in the ground yet!!!!! lot s and lots of rain. getting sick of it!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 06-11-2010, 09:51 AM   #15
oldblue1968chevy
have you pulled your cowl off yet?
John
Old 06-11-2010, 03:57 PM   #16
Already Gone
No I just finished 4, 12 hour nite shifts in a row and have a busy weekend ahead. I'll be parking the truck for the season in a month or so and will check it out before I park it. I 'm gonna take the truck apart in the next year anyway as I just ordered the bedstrips and bolt kit from Mar-K. I have have an ECE rear gas tank to install and buckets with the integrated shoulder belts and console from a 2003 Chev truck. I've planned to go to California this October for the Pomona Swap Meet and want to stop at ECE on the way home and pick up carpet, a 3 1/2 5 drop kit and inner fenders for the box.
