Old 06-11-2010, 10:29 PM   #1
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I just lost 100lbs on the Porterbuilt diet
Well something like that. I'm sure the new Dropmember with tube arms will weigh a lot less. Hey Nate have you ever put them both on a scale to compare? Old vs. New.
DRTYRAT30 is offline   Reply With Quote
Old 06-11-2010, 10:49 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: I just lost 100lbs on the Porterbuilt diet
Cool man...I have wanted to see some detailed Pictures of one of these installs...
I'm going to have to follow along and check out all your progress.
Keep post pictures...I want one of these drop members
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-13-2010, 01:07 AM   #3
shrunken66stroker
shrunken66stroker's Avatar
watching closely.
shrunken66stroker is offline   Reply With Quote
Old 06-13-2010, 01:48 AM   #4
64c20crewcab
64c20crewcab's Avatar
me too!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 06-13-2010, 02:15 AM   #5
spr85gmc
spr85gmc's Avatar
me too but for the love of jeebus put some shoes on yeah your hand are clean but i think your toes are just as important...imho
spr85gmc is offline   Reply With Quote
Old 06-13-2010, 01:28 PM   #6
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Funny, I have always worn my sandals in the garage, check back on my build thread you will see me in them on my roadster build. Plus i have a nice toe tan from welding in them also. I guess when you wear steel toes 10hrs a day its nice to sport some sandals on the weekends.
I'm glad you think my toes are important, I'll be careful
Old 06-14-2010, 11:26 AM   #7
creep
Registered Loser
creep's Avatar
Maybe you can find some steel-toed sandals.
The aftermarket crossmembers are the coolest idea. I have one on my 63 GMC that I'm building and it sits the pinch welds about 1/8" off the ground.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-19-2010, 12:52 AM   #8
DRTYRAT30
Jesse
DRTYRAT30's Avatar
If i run a 27" WW on a steel smoothie will i be on the pinch weld or is the frame an 1/8th lower
Old 06-24-2010, 02:27 PM   #9
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Well here is a comparison picture of fat greasy & old and skinny clean & new
Old 06-24-2010, 02:53 PM   #10
shrunken66stroker
Nice! What a great set up. Nate does some fine work and I'll be happy to write the check once I have the $ to back it up. What rack and pinion are you going to use with the drop member?
Old 06-24-2010, 03:04 PM   #11
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I think the one from Summit, I have herd good things on them.
And there on sale
http://www.summitracing.com/parts/SUM-770601/?rtype=10
Old 06-24-2010, 03:22 PM   #12
shrunken66stroker
That's a lot cheaper than I thought it would be. Keep us posted on the install and ofcourse, we need some pics. Thanks
Old 06-24-2010, 03:38 PM   #13
dallas71
dallas71's Avatar
How do the Uppers Connect? And who makes this crossmember setup?
dallas71 is offline   Reply With Quote
Old 06-24-2010, 07:03 PM   #14
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Its from Porterbuilt Street Rods
http://porterbuiltstreetrods.com/site/
Old 06-24-2010, 11:34 PM   #15
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Well That rack wont work you need the 1979-93 style. So i think i will go with this one.
http://www.summitracing.com/parts/FLA-FR1503/?rtype=10
Old 06-25-2010, 09:27 AM   #16
creep
Registered Loser
creep's Avatar
Mine lays frame but the pinch weld is still about 1/8" off the ground. With the PB x-member and 3" drop spindles you should be able to lay frame on 29.5" tires.
Old 06-28-2010, 12:50 AM   #17
65Pickup
65Pickup's Avatar
How is your build progressing? Sounds like a great wheel set up. Any idea how a manual rack will perform in our heavy trucks???
65Pickup is offline   Reply With Quote
Old 06-28-2010, 06:35 PM   #18
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Well i hear its not as easy as power but i want to keep it simple and i think a flaming river rack (1503) with the tire size im running should be fine plus my truck is losing weight.
Progress wise im sanding and painting parts getting ready to install, its 103 here today so not interested in going out in the garage.
Old 06-28-2010, 07:43 PM   #19
54Caddy
GM Addicted
54Caddy's Avatar
Looking good and ahaha you must be around the valley somewhere this heat is getting bad. You should weight it all and see how much weight you lose.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 06-28-2010, 08:25 PM   #20
65Pickup
65Pickup's Avatar
I hear ya, got a motor coming from Delaware its 109 F back east, that's too high. We were there last summer, but cold so far.
I had the same thoughts on mine, keep it simple, didn't want the pump. Just curious if a rack eases the turn effort...factory GM stuff really builds muscle. Later.
