what is the difference between the 67-68 parking brake system and the 70-72 parking brake system besides the lever in the cab?
Restoration Virgin!
Re: parking brake lever
67/68 is hand operated and exits the firewall in a different spot than the 69-72 e-brake which is foot operated
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
I have a 67 cab on a 70 frame, which parking brake set up do I order for my truck then?
Posted via Mobile Device |
Restoration Virgin!
check out this diagram.....the first one is the diagram for the routing of a 67/68 ebrake....the second one is the firewall of a 69-72 (can't remember which year).....notice that the 67/68 exits under the hole for the steering column.....the 69-72 one exits to the right of the electrical bulkhead area
I think you should order the 67/68 one due to the fact that the fuse block on the interior of the 67 cab is turned 90 degrees and may interfere with a foot operated pedal one, unless of course you are going to change the wiring up too and want the foot ebrake???.... The other thing that I'm not for sure on is where the intermediate ebake cable (the one connected to the hand ebrake or foot ebrake) attaches to the frame after it exits the firewall.... Hopefully someone else will chime in to clarify for us ![]()
Restoration Virgin!
btw...I checked this web site....http://www.inlinetube.com/....looks like they need to know what kinda of tranny you are running as well.....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 04-26-2011 at 05:33 PM. |
