Sensitive steering. Need help
Has anyone ever had the issue of real sensitive steering. When I'm driving say 30 mph or faster, and I hit a rut or as we have here, miles of ruts, my truck will easily pull to one side. The dangerous part is that my steering is so "touchy" that when i try to correct it, it will sling shot me back to the other side. I've change the power steering box once and it stayed the same. Any suggestions? I have 18 in wheels, disc brakes up front and lowering springs.
#2 | |
Re: Sensitive steering. Need help
I would say that you have an alignment issue. Probably not enough caster in the first place and likely some toe-out to make it worse.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
![]() Join Date: Mar 2005
It sounds like your caster is way off. Little or no caster will exhibit symptoms very close to what you're seeing. I like a lot of caster because it makes the vehicle track down the road better and you're not constantly trying to bring it back on center all the time.
Hate to sound ignorant, but what exactly is Caster and how do i correct it?
BMW & ASE Master Certified
unless you have an alignment rack, you cannot correct it. You will have to take it and get your truck aligned by someone.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 07-30-2010 at 03:36 PM. |
I agree that its alignment. Mine was fine before i cut the springs, now it follows the road everywhere and especially patch jobs. My problem is I now have negative camber (tires are pointing inward). Look at your tires and see if they're tilted in or see if the tread is worn down on the inside.
