Old 07-21-2010, 11:50 AM   #1
dalbers
dalbers's Avatar
Brake lines and trailing arms
I am going to replace all the trailing arm/rear end bushings and the brake lines on a frame I picked up. Where is the best place to get this stuff?
dalbers is offline   Reply With Quote
Old 07-21-2010, 12:53 PM   #2
BarryB
BarryB's Avatar
Re: Brake lines and trailing arms
I'd like to know the best place for brakelines myself. I know there are several vendors on board that sell these items but I'm not in the know of who or where they are.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-21-2010, 01:21 PM   #3
dfwright
dfwright's Avatar
I bought my bushings from classicparts.com
The rubber brake lines, I bought locally through carquest.
I haven't done the hardlines yet, but there seems to be two recommendations I've seen. Most recommend buying the lines and bending your own. Those who do buy pre-bent lines usually mention inline tube.
I've also seen mentioned here that the pre-bent lines from LMC are inline brand.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 07-21-2010, 01:46 PM   #4
rollinhard
rollinhard's Avatar
The brake lines kit that i got with my project are from Fine Lines dont know if there any good but thats what ill be use'n
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 07-21-2010, 02:11 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
My whole truck is done with lines from the right stuff
http://www.getdiscbrakes.com/RightStuff/Default.aspx
The last tube I picked up several weeks ago for another product was all made in the usa stuff
Dave also sells to Jegs, Summit and Chrysler amoungest others.
The back brake lines where spot on.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 07-21-2010, 04:22 PM   #6
swierker
swierker's Avatar
This could be true but LMC is about $40 more than inline tube or GMCpauls for the full kit. Not sure if GMC Pauls is inline tube or not
swierker is offline   Reply With Quote
Old 07-21-2010, 04:31 PM   #7
capev86
i replaced the rear hard lines on my 72 burb w/ coated lines from VIP and all 3 brake hoses went bye bye in favor of stainless braided ones from Inlinetube.com.
capev86 is offline   Reply With Quote
Old 07-21-2010, 06:57 PM   #8
dalbers
dalbers's Avatar
How hard is it to do your own lines? I've never done em before.
Old 07-21-2010, 06:57 PM   #9
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
dont quote me on this, but iirc inlinetube gets their truck kits from the right stuff.
ProStreet68SB is offline   Reply With Quote
Old 07-21-2010, 07:10 PM   #10
Sammy
Comments before seem that Dbl flaring brake lines require special tools and lots of trial and error. Why, take a chance to save a few bucks on something as important as stopping your truck at 70 MPH.
Inline tube is what I used on the GMC they were so close only slight adjustments required. I would use them again.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-21-2010, 07:45 PM   #11
dalbers
dalbers's Avatar
good point sammy
Old 07-21-2010, 10:52 PM   #12
bigsnookmaster
bigsnookmaster's Avatar
I did my own, and with a good double flaring tool it isn't too bad,unless your using stainless. I also re-routed my lines, moving the rear line to the drivers side, and my front line to go in front of the crossmember, and back to the prop valve. This keeps all the brake lines away from headers and heat, we know heat kills brakes, so why cook the fluid? My .02
bigsnookmaster is offline   Reply With Quote
Old 07-22-2010, 02:33 AM   #13
ERASER5
ERASER5's Avatar
??? A double flare is a piece of cake. Just follow the very simple instructions. I have done many for both my vehicles and customer's. Special tools, yes, but so what? A torque wrench is a special tool. I'll trust my flares in any vehicle, any time. Just because you bought something does not mean it is good. A close inspection of a flare is always required.
I highly recommend the nickle-copper alloy brake lines. No rust, easy to bend and flare (even for newbies). I just recently replace my brake lines from the ABS all the way back to the wheel cylinders on my Durango. And they were bubble flares at that. Perfect flare every time.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-22-2010, 09:04 AM   #14
68gmsee
Active Member
68gmsee's Avatar
[QUOTE=ERASER5;4101074.... I highly recommend the nickle-copper alloy brake lines. No rust, easy to bend and flare (even for newbies)..............[/QUOTE]
Where do you get the nickle-copper alloy brake lines from?
68gmsee is offline   Reply With Quote
Old 07-22-2010, 10:20 PM   #15
ERASER5
ERASER5's Avatar
AutoZone carries it now. I bought the 25ft roll and cut to fit, flare, and bend.
Eastwood also has a pair of bending pliers for about $30. The pliers are perfect for the nickel-copper lines.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
