Old 07-27-2010, 03:24 PM   #1
Kamloops83GMC
What's under that cap??
Has anyone popped the cap off the C post on an early crew cab to see if it's threaded for a shoulder belt attachment? Looking at a nice 1981 3+3 for 1000 bucks, but need to make sure the car seats and booster seats will work in the future.
Thanks!
Kamloops83GMC is offline   Reply With Quote
Old 07-27-2010, 04:56 PM   #2
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: What's under that cap??
Thanks!
both my 84 and the new 85 cab had
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 07-27-2010, 05:56 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
I'd trust a tethered car seat with its own buckles 1000 times more than I'd trust a shoulder belt holding the car seat in place. Especially a seat belt from the 80's. Using the tether system to secure a car seat is a lot easier, tons safer and a whole lot more secure.
Did the whole baby seat training and 'buckle baby right' stuff when I worked for Hertz Rent A Car. We could not use factory seat belts unless it was just for a booster seat, then of course the seat belt is the only option since the booster has no built in harness like infant/toddler/child seat does.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-27-2010, 08:27 PM   #4
USSkoval
My '79 just has empty holes there. I strap the child seats in with just the lap belts and it works fine. I put all my weight on the child seat while buckling the belt, and make sure the belt locks in place. It feels like it's mounted well, not floppy at all.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 07-27-2010, 09:00 PM   #5
cableguy0
The tether system is out of the question in an older vehicle the mounts arent there.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-27-2010, 09:17 PM   #6
Davidmichael
Davidmichael's Avatar
I know in my burban, there are no tethers at all. The only option is the seat belts. Now with my son's car seat, I can only use 1 rear seat due to the fact I do not trust any of the other seat belts.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 07-27-2010, 09:21 PM   #7
RandyP
RandyP's Avatar
You add them. Very easy to do.
Old 07-27-2010, 09:42 PM   #8
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
im interested in how you say "add them" I dont think it is as easy as that, it would have to be something that is thru-bolted at least to hold the force just in case something does happen.
staggerd86c-10 is offline   Reply With Quote
Old 07-28-2010, 12:52 AM   #9
Kamloops83GMC
Were shoulder belts an option you could buy in 1980? Has anyone popped the cap off to see if it's threaded or an empty hole?
LMC Truck sells shoulder belt kits so the booster seat will work in the future.
Old 07-28-2010, 07:38 AM   #10
RandyP
RandyP's Avatar
You install a small U bolt type connection, or even a cargo type anchor on the back of the cab wall and along the bottom by the package tray. That would give you the three mounting locations you need. If you don't think the cab sheet metal is strong enough, you can reinforce with a backing plate. If you don't think screws are strong enough, use nuts and bolts, if you don't think that is strong enough, you can weld it.
As long as the tether strap can pass between the seat bottom and seat back (can't really think of a car/truck they couldn't), you can use a tether system once you add brackets.
Old 07-28-2010, 09:09 AM   #11
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I added a tether attachment on a truck for a buddy of mine. U-bolt through 1/8 plate then through the floor, through 1/8 plate again sandwiching the floor between the two pieces of 1/8 plate and then bolted in.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
