C35 Crew Dually
Bed mounting bolts.
i need a new set any onw know off hand the leangth,diameter and such? was just going to go down to the local bolt shop and get them i knwo there are 2 diffrent sizes. mines a long bed dually if it makes a diff...
thanks Dru |
Re: Bed mounting bolts.
I just went to the local hardware store and pick up Carriage bolts. I don't know the lengths right off, you will need 6 shorter ones and 2 longer ones. The longer ones were longer than I anticipated, but I never went back to get a longer set. I figured 6 out of 8 should hold it, and it did. The 6 short ones are probably 5-6" long as they only go through a short mount and the upper part of the frame. The longer set goes all the way through the frame.
This was on a 1/2 ton long bed, so it should be pretty close if not the same on yours. I do not know how much difference a 1 ton dually would make. If you already have a bed mounted I would remove 1 of each length bolt and take with you. If you do not have any bolts, measure the length and diameter of the mounting holes. Add a bit to the length though so the bolts stick out far enough to tighten the nuts onto the bolts.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
3/4" dia cairrage bolts, and it'll be the same dually or not (dually is just a reg box with the fenders modified)
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 ![]() and some K5's lol |
C35 Crew Dually
