Old 08-08-2010, 07:56 PM   #1
jiggityjoe87
Engine cutting out???
Hey everybody, been a while since my last post but recently i've been experiencing some technical difficulty with my 70' suburban. To give you the brief overview of the powertrain I have a 350/700-R4 the engine has a 1406 edelbrock 600 cfm vac secondary w/ elec choke. I have a HEI ignition in the burb and I have vortec heads as well. The problem at hand seems to happen when I am going up the hill to my house it is about a 10 mile stretch with a pretty constant grade, so I go up the hill at about 1/2 throttle and suddenly it feels like either the engine is not getting the fuel it needs or that the spark lighting the cylinders has dropped to a much less voltage. The engine will be unresponsive and very sluggish. At this point I pull to the side of the road and the engine will idle like normal and I proceed to rev the engine to "clear it's throat" after that I get on the road and it's fine. Now I think of a few different things that could be causing this.
1. Dirt in the carburator that temporarily causes the stalling
2. Ignition module on the HEI. I don't know the symptoms of a failing unit but this is just a guess
3. Fuel Pump can't keep up with the engine at that RPM and drains the fuel bowl causing the engine to stall out
Those are the 3 things I can think of off the top of my head. Any input is greatly appreciated. thanks
jiggityjoe87 is offline   Reply With Quote
Old 08-08-2010, 08:24 PM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: Engine cutting out???
I would change the fuel filter first. Maybe the pump, if you could test the pressure, would help.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 08-09-2010, 01:49 AM   #3
tim21391
tim21391's Avatar
had same problems.. make sure to see that your secondaires in the carb are opening up.... take air cleaner off.. then have truck shut off.. and get up in there to the carb.. and push the throttle thing back on the carb to full throttle and theres a lever on the side and then push that up towards the hood and look down the carb to see if they are all opening
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
