Old 12-16-2010, 10:35 AM   #1
Patsfan34
Patsfan34's Avatar
WTB 4x4 rear U-bolt
I need one rear U-bolt with both bolts. I would prefer a matching one like pictured below. This is 68 GMC 1/2 ton 4x4 frame but I assume most of the U-bolts for 1/2 ton 4x4s are the same. The bolts measure 7/8s. I have 5 leafs in the leaf springs. Shipping would be to 06615. Thanks, Neil
Patsfan34 is offline   Reply With Quote
Old 12-16-2010, 11:09 AM   #2
sharpie1972
Re: WTB 4x4 rear U-bolt
Hi Neil, I have one from a 72 I can send you. I'll get a picture and measurements for you tonight. Thanks, Sharpie
sharpie1972 is offline   Reply With Quote
Old 12-16-2010, 07:24 PM   #3
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Is that the stock setup? I don't recognize that saddle....I thought they used a cast saddle and it went on the bottom of the axle tube with the u bolts facing down...more of a squared u bolt that wraps around the leaf pack instead of axle.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-16-2010, 10:11 PM   #4
Patsfan34
Patsfan34's Avatar
As always it's Dennis to the rescue! Thanks so much and happy holidays.
Neil
Old 12-16-2010, 10:14 PM   #5
Patsfan34
Patsfan34's Avatar
I'm not 100% sure mine is the stock set up but I think it is. Blazerman I've seen what your talking about on trucks with a lift kit. The square u-bolts are usually for holding the blocks in for the lift kit, at least that's what I thought.
Old 12-16-2010, 10:38 PM   #6
sharpie1972
Pics of stock 72 U-bolts. Looks like these came from a K20, also a new set same bend just smaller diameter. 4 " wide outside 8 1/2" long 1/2" and 5/16" diameter respectively. Let me know if one of these will work and I'll get it headed your way. Sharpie
Old 12-18-2010, 12:48 AM   #7
Patsfan34
Patsfan34's Avatar
Dennis I'm pretty sure one on the left will work. Can you just confirm the bolts are 7/8s? PM me what I owe you with shipping and I will paypal you sometime this weekend. Shipping to 06615. I will take the one that requires the least amount of wire brushing and nice straight threads. Thanks again so much!
Neil
Old 12-18-2010, 06:47 PM   #8
sharpie1972
Hi Neil, the nuts on those are 15/16ths and 3/4 on the smaller ones which fit my stock sadlle. Sharpie
Old 12-19-2010, 12:08 AM   #9
Big-Blue
Big-Blue's Avatar
I have always heard that you shouldn't reuse U-bolts. I am guessing it has something to do with stretching/yielding and not up to 100% strength.
Anyway, a spring shop can bend you new ones for about $12.
Big-Blue is offline   Reply With Quote
