Old 08-18-2010, 08:51 PM   #1
chainsaw
chainsaw's Avatar
gas sender
I'm replaceing the tank sending unit in the 65, I think I have 1/4 to 1/2 tank of gas. Question is how much gas (if any) will flow out of the line from the engine to tank and sending unit when I disconnect it ? Thanks.
chainsaw is offline   Reply With Quote
Old 08-18-2010, 09:14 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: gas sender
If you have only a quarter tank no gas should come out, not sure about the half way point thou, you should also use a long ground strap and keep it grounded while you are removing the sending unit out as not to generate any static electricity....same with install..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-18-2010, 10:54 PM   #3
gulffishin
gulffishin's Avatar
Re: gas sender
If you have the in cab gas tank I don't think any will come out.
When I removed the sending unit from my truck the only gas that I got in my cab was what dripped off the float.
I think it's because the connector for the fuel pick-up on the sending unit is on the top of the tank; fuel can't siphon out if the end of the pipe is above the level of the fuel in the tank.
gulffishin is offline   Reply With Quote
Old 08-18-2010, 11:39 PM   #4
chainsaw
chainsaw's Avatar
Re: gas sender
Thanks guys, I didn't want to flood my cab.
Old 08-19-2010, 03:45 PM   #5
gulffishin
gulffishin's Avatar
Re: gas sender
Be sure to keep your windows open. Just b/c no liquid gas gets in your cab doesn't mean its safe. Fumes will still be escaping from the sender hole.
Old 08-19-2010, 05:56 PM   #6
NCD1966
NCD1966's Avatar
Re: gas sender
changing the sending unit in the cab is pretty easy. As said above "only gas that I got in my cab was what dripped off the float"
Last time I changed mine was on my lunch our at work. took about 10-15 mins. I kept my doors open.
Might be a good idea to disconnect your battery. just a thought. I dont believe I disconnected mine when i did it though.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
