Old 08-28-2010, 07:10 PM   #1
Sammy
Air Valves Quality
Are the valves like most everything else you get what you pay for? Reason I ask been researching air system kits. Airbagit.com has some complete systems with some decent prices even after you upgrade up the scale for 1/2" valves, 5 gal tank their prices are rather reasonable. And they have been in the business for a long time. Just wondered if anyone has any experance or stories about the quality of their stuff. SDC valves seem to be the caddy valve to use with a similar price tag? Feedback..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-28-2010, 08:19 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air Valves Quality
Originally Posted by Sammy View Post
... Airbagit.com .... Feedback..
You will find that the general opinion on this forum is DO NOT buy from AIM, Chassis Tech, airbagit.com or any of their other aliases. They are noted for inferior quality products, and very poor customer service.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-28-2010, 10:02 PM   #3
Shane
Shane's Avatar
yeah ... it's crap. stick with SMC or Parker and you will be far far ahead in the long run.
***************** also sells "kits" ... check 'em out.
Shane is offline   Reply With Quote
Old 08-29-2010, 12:03 PM   #4
texastrendz
i am running gc extreme valves, i like them because they have Din style connector . No cutting and splicing, and they are weather tight. Run the wire through the connector, strip wire and tighten the screw. Real simple and clean and the valves are reliable.
texastrendz is offline   Reply With Quote
Old 08-29-2010, 11:52 PM   #5
blime81
Laid Lo
blime81's Avatar
I'm running Air Lift valves. I like them. I have 3/8s and they are pretty quick (1/2s are too quick for my liking) and air lift is located here in the states so if something does go wrong it's an easy fix.
SMCs always seem backordered. Not cool of something goes wrong.
I use connectors on mine too. Didn't come with them though. The weather pack connectors at www.k-four.net are great for everything. I used a 4 pin for each side.
Just don't run airbagit junk. Remember that the only thing keeping your truck off the pavement at speed is the valves, bags, fittings and lines. No sense skimping.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 08-29-2010, 11:54 PM   #6
blime81
Laid Lo
blime81's Avatar
Oh yeah I got em from ***************** Call em up and talk to them. They should be able to help you out. Good guys.
Semper Fi,
Jeff
Old 08-30-2010, 11:02 AM   #7
colin_havens
colin_havens's Avatar
A buddy of mine is using one of the manifold valves from AIM, and he spent days trting to find the airleak he had. It basically was in the manifold itself, so he sent it back and got another one. It had the same problem. No issues as far as the occasional cruise, but it does leak down after a couple of days.
Airlift makes a good valve, so does SMC. Im using some from Silverstar Customs, which are SMC that have been relabeled with the shops name on them (they were local to me when I bought them, so I could just run up there and pick up a replcaement if I needed) I have never had a problem with them, except in real cold weather. Once I heated them up, they unstuck themselves.
However, on my next build I will for sure be using an Accuair setup. That has the be the slickest setup on the market.
http://www.accuairsuspension.com/
You can use their E-lever setup, with automatically levels your ride, or the Switchspeed setup, which is non leveling. Amazing stuff, but not vheap either. But if thats what is holding your truck up off the ground, would you really want to skimp and by cheap valves?
colin_havens is offline   Reply With Quote
Old 08-30-2010, 11:26 AM   #8
dropd80s
dropd80s's Avatar
I have used SMC on everything I have built with little problems and consider them a great valve. The only time i have had my SMCs stick was on my g/fs S10 in the cold before we had water seperators on and they froze. I do think that parkers are better (or the best) valve. Every one i know that has run them has never had a single problem and never had them "stick". I plan to run them on my SFBD CC dually.
dropd80s is offline   Reply With Quote
Old 08-31-2010, 09:19 AM   #9
LowSmoothCool
Jon@AirRideTech
LowSmoothCool's Avatar
As others have mentioned there is a huge diffrence in quality. Make sure the valves you purchase are designed for the application, because SMC, Parker, etc. also make valves for industrial use. Our valves for instance are a bubble tight valve with a 0 tolerance for leak down.
Selling The best Damn Air Suspension
www.ridetech.com
jon@ridetech.com
(812) 482-2932
LowSmoothCool is offline   Reply With Quote
Old 08-31-2010, 11:28 AM   #10
tcb-1
Nothing to see here.....
tcb-1's Avatar
big fan of SMC for a good rugged valve. Parkers are a bit nicer imho.... and a bit pricier.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-31-2010, 01:19 PM   #11
fixit-p
fixit-p's Avatar
Asco also makes some quality valves. http://www.ascovalve.com/Common/PDFF...de_V7637R1.pdf
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 08-31-2010, 02:05 PM   #12
JWall
Frequent Flyer
JWall's Avatar
I ran the same set of parkers for 6 years or so with no problems.
- Justin
1 Owner 1976 SWB
Old 08-31-2010, 02:12 PM   #13
stevencvn72
Kill Bill...et
stevencvn72's Avatar
I like the ASCO valve manifolds, but can't find who distributes them. Any other company besides Chassis Tech carry an 8 valve manifold?
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 08-31-2010, 03:56 PM   #14
royo
royo's Avatar
WOW thx for the info
nickle and dime
royo is offline   Reply With Quote
Old 08-31-2010, 04:20 PM   #15
robnolimit
robnolimit's Avatar
Air ride tech. and accu-air make very nice valves. I like to use valve blocks for the ease of instalation. 3/8 is plenty big, 1/2 moves so fast you can't tune in the ride.
Ohh, and aim, I mean ratical tops, or is it airbaggit...... been in bus a long time, with many different names.
No one was every sorry that they bought the best. Do it once, Do it right.
robnolimit is offline   Reply With Quote
Old 09-01-2010, 01:47 AM   #16
nastyc10
nastyc10's Avatar
I've been happy with my GC manifold valves from kpcomponents. They are only 1/4" but I didn't want a fast system. No problems for a year and a half so far.
nastyc10 is offline   Reply With Quote
Old 09-01-2010, 02:22 AM   #17
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Air Ride Technologies FTW!
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
