Old 04-09-2020, 11:01 PM   #1
chtr65
K-10 front axle ID numbers
I have a 66 chevy K-10, appears to be mostly original. Found some stamped numbers on the front axle tube that I could use some help deciphering. Any one know what the numbers mean?
chtr65 is offline   Reply With Quote
Old 04-10-2020, 07:44 AM   #2
b454rat
Re: K-10 front axle ID numbers
Top one is the date, not sure what the bottom is
Old 04-10-2020, 11:03 PM   #3
chtr65
Thanks for confirming the number in top photo. I will assume the other numbers are part numbers. Many Thanks Again.
Old 04-11-2020, 09:18 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
The second set of numbers is whats known as BOM (bill of materials). This set of numbers is used by Spicer to identify a certain axle, if there is a parts change mid year in a Spicer axle then this will identify that axle. When ordering some parts you may need to revert to this number to make sure you get the correct part.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 04-12-2020, 12:35 AM   #5
chtr65
Thanks Blazerman, That's some info probably not alot of people knew about. I certainly didn't. Thank you, this is my first 4x4. I'm learning.
Old 04-12-2020, 08:28 AM   #6
b454rat
Don't think there is enough numbers for the BOM, why I didn't mention it...Its been a long time since I looked up BOMs, but think they start with a 6. Maybe that's just the 60s....
Old 04-12-2020, 12:41 PM   #7
chtr65
I noticed the orange stroke of paint over the black. I suppose that was to mark that the numbers had been stamped. Thanks Again.
Old 04-13-2020, 01:13 PM   #8
BLAZERMAN
BLAZERMAN's Avatar
Correct, 67 on up used a six digit number followed by a space or dash and another single.number. Im not sure about the 66 on down trucks. My Spicer manual is for 67 to 78.
