Old 09-14-2010, 10:02 PM   #1
munice
regular everyday normal guy
munice's Avatar
Stuck Axle Bolts 14B FF /Locker Questions?
Hey All , well I finally finished my 3/4t 10 bolt rebuild now im starting the 14bolt, right off the bat, four of the axle shaft bolts wont let up.. One side came apart just fine, not a whole lot of force needed but the other side is being a bugger. I soaked them all in penetrant but to no avail. And I wasn't sure how I would go about heating them up if that would even work.
Other question I had: I'm in Southern Ontario right beside Port Huron michigan, where abouts would i be able to get a Detroit Locker? From my research, Ive gathered that for the 10.5" ring gears the locker just replaces the inside of the carrier. I looked on jegs, but they only had the one for 4.56 and up (mine is 4.11) I wasnt sure if its something that can be ordered through oreilly's or not? Or what other units work for the 14ff's? My truck isn't a serious offroader but it does get to play once in while
here's the finished 10 bolt and the 14
munice is offline   Reply With Quote
