Fixable ?
Got a hood thats in pretty good shape as far as rust, but there is a crease on the passenger side front
i could probably build it up with weld and grind down also has a place in very back in middle that has been pushed down, im thinking of adding a third brace between the original two , put a piece of foam in there to keep the shape am looking for ideas Thanks
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Fixable ?
That doesn't look too bad. You probably know they make and sell both Upper and lower front sections of the hood. I had mine replaced.
Re: Fixable ?
Yes, i do know they sell the upper and lower, trying not to have to deal with hundreds of spot welds, but i will, lol
if need be Thanks
But Found Her 25yrs Later!
Re: Fixable ?
Why not just use a good body filler for that small ding.
Re: Fixable ?
Easy fix. Using a grinder cutting wheel cut out a slot, the width of blade, along the red line. Then use a chisel or screw driver to work the metal back up and open to the seam. Once you have the seam straight weld the slit back.
Re: Fixable ?
Great solution.
Re: Fixable ?
nice, think ill give it a try, bottom has slight dent also, not as bad as top
