Old 10-03-2010, 08:56 PM   #1
Raider Rudy
Raider Rudy's Avatar
Steering Question
I have a 69 K10 short bed step side. When ever I make a turn, the steering wheel is out of clock 90 degrees. If I make a r/turn & then go straight my steering wheel is out of clock 90 degrees to right. If I make a l/turn the same thing happens to the left. After I drive straight for a while it corrects itself. It is not the gear box because I just replaced it & there is no change. Anybody got any ideas?
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
Old 10-04-2010, 12:15 AM   #2
raycow
Re: Steering Question
Have you checked for play in the linkage? This means every single rod end. I would think a quarter turn worth of play has to be visible somewhere.
Ray
raycow is offline   Reply With Quote
Old 10-05-2010, 08:55 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
Also check where the rag joint attaches to the steering box.
Check to make sure the box bolts are tight.
Make sure the frame is not cracked around the box.
Check the drag link ends for slop.
Check to make sure the steering arm bolts are tight.
Check the center link ends.
Ummm......make sure the steering wheel is tight.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-05-2010, 10:29 PM   #4
Raider Rudy
Thanks! I'll check it all.
