68 c10 bumper and brackets on a 72 blazer???
I found a steal on this bumper and bumper brackets but I dont know if everything will match up...anyone able to tell me??? Please???
Re: 68 c10 bumper and brackets on a 72 blazer???
Not likely. The brackets and mounting holes on the frame will be different.
Tim |
thanks tim, is it because the year difference(68-72)? Or is it that I need to buy specific brackets for a blazer?
Front or rear?
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
The bumpers and brackets are the same, just that there is no holes in the bumper for the turn signals / parking lights.
The frames are all the same from 1967 to 72' The parking lights in the 1967 - 70 are in the grill assembly and the 67 parking lights went out when you turned on the headlights. |
![]() Join Date: May 2006
2wd or 4wd?
@ monte carlo man, my turn signals are in my grill, I have a 68 front clip on it...are you saying it should work and match right up?
Phat Tony, it would be the front. jaros44sr both the truck and blazer are factory 2wd |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Here's Mine it bolted right on.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
thats a friggin sick blazer...shoot me a link wehre I can see more pics??? I actually live in hanford so were neighbors
TILT COLUMN GURU
Hanford! You can come to our get together in At-water Oct 2 and see it in person.
Pm me the details...ill do my best to make it!!!
so the bumper and bumper brackets on your blazer are from a 68? |
#12 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
67-70 bumpers and 67-70 bumper brackets will bolt right on your '72 blazer. (You will have problems if you try to use a 67-70 bumper with 71-72 brackets.)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-01-2010 at 12:21 PM. |
#13 | |
Mine is 4WD, so it will be difficult for me to give you the correct measurement. I have a '68 front clip on my '72 Jimmy
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-01-2010 at 02:12 PM. |
#14 | |
TILT COLUMN GURU
Yes my bumper brackets are 68
#15 |
The give away is the side marker lights in that Blazer and the chrome bezels.
All 67's did not have side marker lights and most did not have chrome around the grill and light bezels. They were painted. The frames were all the same. The bumper had a bracket that bolted to the top of the frame that looked like a small angle iron with a hole on each end. The bumper brackets might have been longer to go more towards the edge of the bumper because the turn signals were slightly away from the edge of the frame on each side and the brackets had to be moved further over to make room for the light housings. The bottom hole in the frame bolted directly to the bumper the way I remember it. |
#16 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Does anyone have pics of the different brackets???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#17 |
Id also like to see!
#18 |
born to lose
I love doing a search and getting the info I need without making a new post. Thanks board!
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
