Old 10-21-2010, 03:14 PM   #1
Tink
Tink's Avatar
Loose Steering Column - repair or just buy another?
The steering column in our 69 C10 is loose... has a lot of play in it and you can grab the steering wheel and move it quite a bit - up and down, side to side. The outside of the column seems stable, so I'm assuming it is the internals... looks like there is a lot of bearings in there. Is it worth buying the parts from LMC to rebuilt it or should we just buy a used one?
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 10-21-2010, 04:27 PM   #2
cdowns
cdowns's Avatar
Re: Loose Steering Column - repair or just buy another?
try taking steering wheel off and tightening nut on shaft to try and remove slop// also check bottom of shaft where it comes out coulmn there is supposed to b spring and washer there(good pic in lmc catalogue)
Old 10-21-2010, 04:40 PM   #3
tubbedII
needs more $$$
tubbedII's Avatar
Good advise. Mine had a lot of slop in it too. I messed with the bolts next to the shaft in the engine bay which took care of the back and forth. The side to side looks to be a worn bearing that you can buy from the catalogs...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-21-2010, 04:41 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
The bearing replacement will cure alot of the slop, if its not a tilt column its pretty easy to do yourself. There are only two bearings, top & bottom one.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-21-2010, 06:15 PM   #5
my67c20
Just did this last winter. Piece of cake. Striped it down cleaned it up painted works like a champ. Down on the bottom end were the spring rides it had worn the shaft down. Welded her up good as new. Bought the parts from LMC
my67c20 is offline   Reply With Quote
Old 10-22-2010, 08:19 AM   #6
Tink
Tink's Avatar
Thanks guys. Looks like LMC will be getting more of our money. I like the idea of cleaning it up and painting it too... especially since the truck is a different color now.
69 Chevy C10
88 Sierra
02 2500 Suburban
