Old 11-05-2010, 06:20 PM   #1
drsergio
drsergio's Avatar
1969 gmc lower /spindles/drum brakes
Got new tires and rims for the truck,,,and I would like to lower the front with drop spindles 2 1/2..Can I do that and keep my drums original brakes ? or I have to change to disk brakes??? Is that a big job to change the front brakes? any pictures or links?
any way just to lower and keep the drums?
ty
drsergio is offline   Reply With Quote
Old 11-05-2010, 08:50 PM   #2
dash13
Re: 1969 gmc lower /spindles/drum brakes
You need to have front disks. Have you already dropped the front with springs?
dash13 is offline   Reply With Quote
Old 11-05-2010, 09:11 PM   #3
drsergio
drsergio's Avatar
Not yet,,,,was thinking on just lowering the springs first and the shocks,,,,,,
would that make a hard ride??
so i have to align the truck again?>
Old 11-05-2010, 09:20 PM   #4
ATrain707
i lowered my 68 truck with springs and drop shocks 3in drop in front and 4in in back. i hope is helps?
i wanna lower the front more but to in stall drop spindles u have to convert to dic breaks i was told.
here a kit. http://www.classicparts.com/1963-70-...info/71-977D6/
ATrain707 is offline   Reply With Quote
Old 11-05-2010, 09:21 PM   #5
drsergio
drsergio's Avatar
looks good ,,, how is the ride?
did you had to re align ,,,does run hard?
Old 11-05-2010, 10:03 PM   #6
ATrain707
i like how it rides, its a little stiff, didnt have an align yet. i was always told should get one done anytime you lower a car/truck. have you looked at lowering kits yet? i order my kit from ebay all four spring ran about 200 and the shocks i ordered from summit racing they are toxic drop shocks made by pro comp and they ran about 70 for the pair i only have those in the front in the rear i ran highjacker air shocks
Old 11-05-2010, 10:39 PM   #7
dash13
I picked up a 3"/4" lowering kit from CPP from a guy named Jeff Norton I met off of this site. It ran me around $300. It came with springs and shocks. I hope to get them installed this weekend or next week. Ill let you know what I think.
Old 11-08-2010, 12:23 PM   #8
drsergio
drsergio's Avatar
Any idea,,,,how much mechanics would charge to put a disk brake kit and the lower spindles?
ty
Old 11-08-2010, 02:01 PM   #9
csutter
I did mine myself on a weekend and I am no mechanic, this is a doable job with out much need for special tools or knowledge. I bought a kit from early classics had everything I needed to replace the spindles and install disk brakes. I was pretty nervous about trying to do this myself but decided to give it a go and I am glad I did, it was challenging but I learned a lot and gained some confidence to try some other jobs. I am rebuilding the rear drums starting tonight.
csutter is offline   Reply With Quote
