K20 454 and TH400 upgrade snags
Hey guys.
I finally had two guys come help me drop the Gen6 454 into my engine bay after I tore the front grill/rad support/head light assembly out and I ran into a few snags... Issue #1) The PS pump that came with the brackets I'm using have one screw in hose fitting and two clamp/clamp on hose fittings which I was told were common on the hydroboost systems. 1 screw in hose was for the high pressure line to the steering box, 1 low pressure return from steering box and one outlet that ran to the brake booster... Do I need a different pump that will work with this bracket setup (from a 2000 454 vortec) that has just the high out and low return lines, or can I cap the one brake booster fitting and call it a day? Issue #2A) When trying to unbolt the front clip/rad section, I snapped both of the large body mount bolts. Are these common bolts or would I need to order specific ones? Issue #2B) I suspected a broken body mount near the front passenger corner and once I freed the rad support section I noticed that the 'ring' portion from the frame was now a large "U" shape... Can I simply get a flat square piece of metal tacked on top and drill it for the large bolt, or do I need to do some serious junkyard scavenging? Issue #3) When I started reinstalling my transmission cross-member, I quickly realized that my original 4spd cross-member wasn't going to reach the bottom of the TH400-NP208 adapter I bought. Do I need the taller adapter, a different cross member (if so, which one?) or is there a spacer that I can use to make up the gap? I found different crossmembers and the taller adapter on this site http://www.justchevytrucks.com/truck...sfercases.html but I thought I'd ask before buying more parts I may not need... Last edited by Rede; 10-24-2010 at 10:31 PM. |
Re: K20 454 and TH400 upgrade snags
Real S-M-R-T question here, but the cross member is supposed to arch up, or down like a cradle??
I was trying to bolt it back in so it was hanging down and I just ran across a picture of one arching up and it made me question as to weather I was bolting it in wrong, which would explain why I the bolts had those odd collars/sleeves and why the bolt holes didn't line up worth a damn... If it arches up, then do the collar pieces go between the frame and the cross member like a spacer like so? ![]() Or does it go like this one? ![]() Truck originally came with the SM465 and NP208, but it's been apart for a while and I've forgotten how it goes together and I'm using a TH400 now so I didn't know if that effected how things lined up or not as well. :| |
#3 | ||
Chevy Enthusiast
Re: K 454 and TH400 upgrade snags
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) Last edited by 1985-GMC; 10-24-2010 at 11:12 PM. |
I solved my crossmember issue by swapping one form a parts truck and drilling an extra set of holes in my frame.
However.... when I was benchpressing the tcase (NP208) with my face, I couldn't get the tcase to slide upto the adaptor. I tried 3 times and each time I cursed more and more, but that still didn't get the transfer case any closer. :@ I was told that the TH400 TRYING to use came out of a 1/2 with a 205 bolted to it when I bought it off of Kijiji. I later tried buying the tcase from him, but he never returned my emails... Do the NP205 tcases use a longer tailshaft or is the difference in the adaptor? (I'm using the shorter TH400 to NP208) I'm taped out of cash, racked up the CC on misc parts and I'm about a 2 weeks away from seeing snow 24/7 here... Is there a simple sollution or do I need to get the tailshaft swapped at a shop? |
Chevy Enthusiast
Im not real sure on the splines that came in th400's and np208's, but if its 32 spline I think the th400 might have came with a long shaft and a short shaft but in not sure. Do they at least have the same # of splines?
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
Yup the 4spd's, th400 and 4L80E all share 32spline.
Problem is that I need to shorten it by 2" ![]() for a brief moment I considered seeing if it can be cut and the splines carefully touched up at the end, but that sounded too good to be true. :P Posted via Mobile Device |
