impala rear disc brackets
I bought a set of impala rear disc brackets with the horseshoe e brake on them.Now I guess I need to inlarge them for the 3" axle and drill the four mounting holes in them ? I got a deal on the whole set up, calipers and rotors.I don't need e-brakes so if its to much trouble to have them cut I might just put the other brackets without the e-brake.Anyone have these cut to fit ,and what did it cost?
big old burb in primer.lot of work to do. |
BMW & ASE Master Certified
Re: impala rear disc brackets
this is what I have brewing. Ive got everthing down except the lenght of the drivers side e-brake cable finialized.. ran out of daylight
http://67-72chevytrucks.com/vboard/s...d.php?t=415021 What does the backing plate look like? take a picture and post it up. Depending on what it looks like I could make a template for you to to drill the right holes in the right spot. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 11-14-2010 at 11:17 PM. |
so it looks like I can do this myself ? I don't need e-brake mybe just buy new brakets and do something with these,someone who needs an e brake on e-bay.Thanks.did you do yours yet?
bought new brackets so I don't need the e-brake backing plates.anyone?
Sent ya PM
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
got it thank you.
